- Aug 30, 2007
- Mchenry, IL
- Automatic
Update, I got the new engine installed in my truck last night, But then a problem arose. I had to spin the motor so that I could get the tourque converter bolts lined up into the flywheel. It spun fine by hand, later after I had bolted the trans to the motor I needed to tighten the bolts to the torque converter. I tried to spin the motor by hand and no spin, I then tried to spin with a socket and no luck. I took out the spark plugs and tried spinning the motor again and no luck. I loosened the 2 bottom bolts on the trans to engine and it spun over. I am now concerned that this will eventually cause damage down the road if this is left this way.. Any ideas of what this could be and if this will be ok to leave like this?
thanks
thanks
