fleck
hey guys, so a few days ago my transmission started to rumble a little going into first gear unless i gave it a good bit of gas. after a while it started clickity clackin, again going into first gear, sometimes randomly. there is also like a rubbing that goes away when i push in the clutch, had been like that for a while. today it finally CLUNK'd out on me and everyone said it was my linkage or syncros. my mechanic came to the scene, shifted it into reverse to a nice hard grinding sound. he can't figure it out though, it runs fine but on the way home it stopped me from shifting again until we let it sit for a couple minutes and went at it again. right now we're both clueless as to what it is. in october we did a master/slave clutch job, replaced the motor oil in the tranny with the proper ATF, and the mechanic that did that job said the clutch was indeed new and the pressure plate looked new and the flywheel looked good. the shifter has always been sloppy (but there are NO bushings where there are supposed to be) and shifting into 2nd without waiting a couple of seconds has always made that too-quick-shift grind noise intermittently.
we're gonna drop the tranny tomorrow but i'm wondering if anyone has any clues.
