Gears for t case?
derekj
15+ Year Member
Squamish, BC
Does anyone make lower gear sets for the 1350?
Derek
Chain driven has nothing to do with reduction sets.
The reduction is a planetary gearset.
No there are no alternate gearsets available.
AD
Crawl boxes are another issue but if that's what you are looking for....
I like the "Stubbler" (because it's SHORT) but It appears that it'll only properly work with a shift lever to work the doubler and an electric shift case behind it....
I'd prefer to see the six pinion planetary from a 13-54 instead of the four pinion piece
(the 6pinion planetary from the 13-54 tends to be quieter)
The atlas is nice if you can afford one...
AD
