| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Let me start off by telling you what I have. It is a 1991 Ranger with the 2.3 duel plug motor in it. It is a manual. I have done some mods to it which include, synthetic oil, NGK plugs, mustang header, free flowing air intake and filter, and electric fan. I have always taken good care of it and changed the oil, plugs, ect. I just changed the timing and serpentine belt about 20,000 miles ago.
Now here is my problem, my truck runs great with the exception of random backfires in the exhaust. I never had any problem out of this truck for the 160,000 miles I have driven it. I bought a new car last year and let my Ranger sit for a few months until the newness of my car wore off, when I started missing my Ranger, I pulled it out, cleaned it up and put some fresh gas in it. Well, I drove it around town about 5 miles each trip for a couple of days and then took it a little farther to a favorite hiking spot which is about 40 miles one way, it drove great and I rode it hard (you have to in order to get anywhere with these underpowered trucks ) all the way there, I parked it for about three hours, on my way home, I made it about three miles before it backfired a couple times out the tailpipe which cut the truck off. It would start right back up and I would get another 50 feet to a mile and it would happen again, no real reason although it seems to do it more under load. If I push my clutch in and let off the gas while it backfires, it won't cut the truck off. I got home OK but had to baby it by doing 35 the whole way. It will backfire randomly on some trips or not at all on others, I replaced the coil, did a tune up, changed the fuel filter, tried different gas, even checked the ignition control module on a tester at a parts store. Do you have any other suggestions? My friend wants to buy the truck but I won't sell it to him in this shape, I need to get it fixed soon. It seems to be more of an electrical problem with how random it is, but I checked or replaced just about every ignition part on the truck, I am hoping it is not a valve problem. Please help me get this problem fixed so I can sell it and buy a new Ranger. Thanks for any help and sorry for the long winded post. |
Tweet
#2 |
Year: 94 extd
Make: Ford
Model: Ranger
Engine: 94 2.3
Class: 2wd
Used For: fun, dd.
Rep Power: 14 ![]() iTrader: (0)
have you checked for vaccum leaks? you said you changed 'the coil' did you change one or both? also you might check the EGR valve out, when mine was stuck open it backfired like crazy.
Tweet
#3 | |
Quote:
I forgot to mention that my tach stopped working around the same time the backfires started, the problems may be unrelated but I am not sure. My truck only throws a CEL when the tach stopps, but not when it backfires. My tach will come back to life sometimes, not sure why, again another random problem but it doesn't work %65 of the time. |
Tweet
#4 |
Year: 1994
Make: Explorer Sport
Engine: 4.0
Class: 2WD
Used For: Work
Rep Power: 15 ![]() iTrader: (0)
Check your camshaft timing belt. It sounds as if it has jumped a tooth.
shady
__________________
Bawney Fwank/Bobby Rush 2012. |
Tweet
#5 |
I just changed the belt about 10,000-20,000 miles ago and it still looks good. I would think if the timing was off, it would run differently and be a more common problem, it is very random. The truck runs great and as strong as it ever did otherwise, I also have no starting problems.
Tweet
#6 |
Einstein I'm NOT
Year: 1988
Make: Ford
Model: Multi-year Ranger
Engine: 2.3 Carbureted
Class: 2wd
Used For: Space travel
Rep Power: 78 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Backfire can be caused by a number of things...unfortunately, they are not that common from what I've read and most are actually due to timing being off...the belt may look good, but that doesn't mean the timing isn't set right...my truck idles fine when the timing is off, but as soon as I give it gas all kinds of things start happening...like the gurgling, chuggling, burping and smoke with flames...
However, you might want to read this article from wikipedia for some more insight...look under causes specifically and you may find the answer if it is not timing... BACK Fire explained
__________________
Rome and my Ranger were not built in a day... |
Tweet
#7 |
Year: 1984,1990,1994
Make: Ford
Model: Ranger, Bronco II
Class: 2WD
I agree with the suggestion that you check your timing belt. And another thing to check, is the plugs.
[QUOTE=fightinggoat15;418972]I have never changed those plugs or wires as they are very hard to get to.[QUOTE] I had a random backfiring symptom in my four-banger, and it was caused by a plug's center insulator being broken. The plugs are a little tough, but it's worth it to pull them for a look-see.
__________________
Current: 1994 Ranger XLT SuperCab 4x2, 2.3L / M5OD. Stock, 365,000 miles. 1990 Bronco II XLT 4x2, 2.9L / A4LD. Stock, 129,00 miles. 1984 Ranger 4x2 lwb, 2.8L / C3. Stock, 148,000 miles. Past: 1985, 1987, 1988, 1989, 1992 (all bought new). Ranger-only driver for 22 years. TRS member since 3/18/2005. |
Tweet
#8 | |
Year: 94 extd
Make: Ford
Model: Ranger
Engine: 94 2.3
Class: 2wd
Used For: fun, dd.
Quote:
Tweet
#9 |
I have changed the plugs and coil on the intake side (passenger side of truck), cannot really get to the other side and I believe it only fires on the exhaust stroke to make sure all the fuel has been burned, I don't think it has anything to do with how the truck runs. If I am wrong I hope someone will let me know, but I think they only did that for emissions. The tach wire might be hooked up to the driver side coil, not sure. The tach doesn't work %90 of the time, the backfire doesn't happen very often, only a few times on a long trip or not at all.
Just changed my coolant temperature sensor yesterday (a PITA to get to), my temp guage works now, but the truck still runs very cool, the temp will come up after long idleing with the fan off, but it never even gets to the middle of the guage. The motor does feel like it is hot though. |
Tweet
#10 |
Year: 1984
Make: Ford
Model: RANGER
Engine: 5.7
Class: 2WD STREET
Used For: BUILDER
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
sounds like you need a t-stat. and i would change the stuuf on the left side of the engine. your coil pack, wires, plugs, could be shorting out. one of the wires might be chaffed just a little, enough to arc against something. i know its a total pita to get to. but its worth it to atleast rule it out as a possiblility
__________________
********THE BUILD THREAD********* http://www.therangerstation.com/foru...ad.php?t=96344 1984 FORD RANGER. 350 CHEVY SWAP. GONE BUT NEVER FORGOTTEN 1990 RANGER. 302 swap in the works ![]() 2001 VeeDub jetta. 2.0 5-speed. The daily driver (for now) |
Tweet
#11 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.3l 4cyl
Class: 2WD Street
Used For: Daily Driven/Toy Hauler
Rep Power: 9 ![]() iTrader: (0)
if you have a cracked header or downpipe im pretty sure it would cause backfire also, i would run seafoam through it to see if it clears it up at all if not id say its definitely an electrical prob.
__________________
88 2.3 XLT 5 Speed,Lowered 2 Inches, Custom Side Outlet Exhaust...Few Other Things....
Tweet
#12 |
I am going to change the thermostat and the plugs/wires on the drivers side today or tomorrow, I hope it will improve something. It will be hard for me to tell if it is fixed since I don't have any tags or insurance for and the problem only happens sometimes.
I did get a new 09' Ranger, they sure have come a long way engine wise, these four bangers are very peppy. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
