Go Back   The Ranger Station Forums > Suspension & Armor > 4X4 Suspensions
Notices
4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks
Post New Thread Reply
Thread Tools Display Modes
Old 05-06-2009, 10:12 AM   #1
bufordanthony
Junior Member
bufordanthony's Avatar
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: What ever strikes my fancy
bufordanthony is on a distinguished road
Default Got the "Ranger Lean" with a twist
My 99 is leaning like most rangers eventually will, but to the passenger side, not the drivers. Checked out the leafs, and all looks well, and the hangers look ok. Everything is pretty consistant 1 1/2 low on P-side. Anything else I should check?
bufordanthony is offline   Reply With Quote
Old 05-06-2009, 10:40 AM   #2
BlackBII
Cheaf of Grammor Poleace
BlackBII's Avatar
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Used For: Getting irritated
BlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to behold
Default
Is the frame lower or is the body lower? Or both?
You could fill it up with a full tank, that should drop the driver's side down some
__________________
I hate all RBV's, especially the ones I own.
BlackBII is offline   Reply With Quote
Old 05-06-2009, 10:45 AM   #3
fastpakr
Super Moderator
fastpakr's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 2.3 Lima
Class: 2WD
fastpakr will become famous soon enough
Default
I wonder if somebody switched the spring packs to cover for the typical problem.
__________________
99 Kawasaki Vulcan 500
1992 F-150 4wd, 5.0/C6
fastpakr is offline   Reply With Quote
Old 05-06-2009, 11:38 AM   #4
bufordanthony
Junior Member
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
Should've included that I have a 4" superlift, and that the stance was fine. Let it set for about nine months in the carport while work was crazy (needed to do electrical work). Finally got it running and noticed it was low on p-side when I was walking towards it in a parking lot. Got home and measured everything (body, frame, shocks, etc...), and found it was all about 1 1/2 difference. The lift blocks on the leafs look good, and not squished. Think it's time for new leafs, or can shocks make that big of a difference?
Old 05-06-2009, 12:13 PM   #5
Tony Raine
Tony Raine's Avatar
Year: 1984
Make: Ford
Model: Bronco II
Engine: 302
Class: 4x4
Used For: a yard ornament
Tony Raine will become famous soon enoughTony Raine will become famous soon enough
Send a message via Yahoo to Tony Raine
Default
is the lean more pronounced in the front or back?
check your coils (on both sides), make sure they are seated properly in the coil bucket. may have to rotate them a little. there's a little "stop" in the bucket that the end of the spring butts up to.
oh crap, wait. you have a 99, so you have torsion bars, right? just play with the bar adjusters until it levels out. crank drivers side "up" or the other side "down" a turn or 2, then drive it around and re-check.
__________________
Click Here to see my FW SAS/302/np435/dana 20 swap in progress
Quote:
Originally Posted by jharms02 View Post
Don't tase me Braaaaah
Tony Raine is offline   Reply With Quote
Old 05-06-2009, 12:27 PM   #6
bufordanthony
Junior Member
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
It's all in the back. Front end is damn near dead nuts (1/8" maybe, and that could be my driveway).
Old 05-06-2009, 12:51 PM   #7
tpking
tpking's Avatar
tpking is on a distinguished road
Default
quit hauling around fat friends
__________________
Quote:
Originally Posted by GB4000 View Post
If I wanted a low rider I would have bought an el Camino.
tpking is offline   Reply With Quote
Old 05-06-2009, 12:58 PM   #8
bufordanthony
Junior Member
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Talking
Maybe I can use this to get the ol' lady to hit the gym... or me.
Old 05-13-2009, 09:48 PM   #9
kris97ranger
kris97ranger's Avatar
Year: 1997 2006
Make: ford
Model: ranger f 150
Engine: 4 litre and 4.2 litre
Class: 4x4 ranger 2wd f 150
Used For: ranger was rolled... working on rebuild. the f150 is for a dd and towing
kris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of lightkris97ranger is a glorious beacon of light
Default
mine does the same thing execpt i have a broken leaf on the drivers side and its lower on the passenger side :S
________
SquirtBOOM
kris97ranger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
