help with lowering kit
bigcountry
15+ Year Member
new market
I think you should have no problem with that, it's DJM products, you will install this, and get the result that they tell you.
If you needed to modify something with the torsion bar, it should be in the kit.
I've buy DJM products, and the quality realy surprised me, and i'm 100% satisfy.
when i turn the torsion bars how is the ride going to be?
hydroxy from explorerfurom
It handles great. I had a friend w/ a 2000 mustang driving with me one time and he said my explorer had less side-to-side sway then his mustang. Have to watch out for pot-holes though, as you can bottom out over big ones. Your offroading capabilities will be that of a car, so if you plan on going offroad, dont lower it. Gravel and dirt roads should be alright though.
other than that i duno, the explorer shares the same torsion bar suspinsion as a ranger, you can
some other just doing a search
http://www.therangerstation.com/forums/showthread.php?t=7517&highlight=lower+torsion+bars
http://www.therangerstation.com/forums/showthread.php?t=2571&highlight=lower+torsion+bars&page=2
other options i have seen is people added air bags, probally could get a djm lower control arm and fab(or get) a coil bucket similar to the 98+ coil sprung suspinsion, then run a coil, alot of work no matter which way you go
DJM parts for the 2wd coil spong ranger will not work on the front of a torsion ranger they are totally different suspensions
