| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 4WD Systems Transfer Cases & Locking Hubs. Forum sponsored by The Shiftster |
Thread Tools | Display Modes |
#1 |
Hey all. I am new to this forum and have seen some nice things. I have a 1987 Ranger V6 with the 2.9l. It has an auto tranny and a 1350 electric transfer case. I now have a 1350 manual transfer case out of an 84 Ranger V6, along with the rear driveshaft. I have the shift linkage as well. My question is what do I need to do or get to make this work in my truck. Any tips? Thanks in advance!
Tweet
#2 |
Logan Andrew Feb 17, 2012
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (15)
The case should bolt right in. The only difference you may encounter is if you have different transmissions in the two trucks the shifter "arm" is different depending on the transmission used.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop. |
Tweet
#4 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
The t-case shifter should not interfere with the automatic floor shifter. The t-case shifter is not centered, it is close to your right leg. There were auto's with manual cases back then, the trick is finding one in a junkyard or something so you can get the proper floorplate and shifter boots.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
