Go Back   The Ranger Station Forums > Suspension & Armor > 4X4 Suspensions
Notices
4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks
Post New Thread Reply
Thread Tools Display Modes
Old 04-23-2009, 06:02 PM   #1
Graham99ranger
Graham99ranger's Avatar
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: daily driver
Graham99ranger is on a distinguished road
Smile explorer leafs into 99 ranger..what year??
hey, i have a stock 99 ranger. it's a 4x4 with a 4.0L. i want 1.5 to 2 inches of lift to clear a set of 31's. i'm gonna crank the torsion bars for the front but i'm not sure about the back. i thought about getting the add a leaf but i think i'd have to re-arch them too because it's leaning to the left. i also want a little more strength back there for hauling loads so i'm not dragging my ass. then i read you can put explorer leafs under it and i thought that might be better. here's my questions:1. what year and style of explorer springs will fit? 2. how much lift will they give and will they be stronger? any help would be appreciated. thanks.
Graham99ranger is offline   Reply With Quote
Old 04-23-2009, 06:17 PM   #2
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
'91-'01 4-dr Explorer leafs. About 1.5-2" lift.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 04-23-2009, 06:35 PM   #3
Graham99ranger
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
cool, thanks a mill
Old 04-23-2009, 06:36 PM   #4
alaskan155
alaskan155's Avatar
Year: 2002 1988
Make: honda and ford
Model: CR-v and Bronco
Engine: 2.4l/5.0
Class: 4x4
Used For: dd/toy
alaskan155 is on a distinguished road
Default
while on subject, is there a difference between v8 and 4.0 rear springs, seen 2 in the pick and pull was just curious(for my B2)
__________________
retired TRS member Currently on
Fullsizebronco.com under same name
current toy:
88 Bronco 35s stock/ no sway bars
5.0/AOD/BWt-case 210k miles
4.10 gears, Rock sliders, chopped quaters
far future mods: D60/10.25 sas/removable doors/custom bumpers
alaskan155 is offline   Reply With Quote
Old 04-23-2009, 06:57 PM   #5
Graham99ranger
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
what is the difference in the spring codes? is there a place that lists and describes them? thanks
Old 04-24-2009, 01:16 PM   #6
WillXLT98
Year: 1998
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 4x4
Used For: learning money management skills
WillXLT98 is on a distinguished road
Send a message via AIM to WillXLT98
Default
You should be able to clear 31s on stock.
I have '30.5' (close enough) and theres no problems whatsoever.
WillXLT98 is offline   Reply With Quote
Old 04-24-2009, 05:36 PM   #7
Graham99ranger
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
yeah, i want it up higher anyway though. and stronger for hauling stuff
Old 04-24-2009, 07:14 PM   #8
Mac
Premium Member
Mac's Avatar
Year: 2003
Make: Ford
Model: Ranger XLT Ext Cab
Engine: 3.0
Class: 2WD Street
Used For: Summer Beater
Mac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond repute
Default
Question on the different codes got me to looking in the '97' shop manual. They do list the codes that go on the door sticker and the different part numbers but - don't give what the spring rates are!
Dave - Know of another place I think I can find them. Didn't know that there were 10 different torsion bars either
Torsion Bar Codes/Part Numbers
B - F57A-5B326-BC
D - F57A-5B326-DD
E - F57A-5B326-EC
F - F57A-5B326-FC
G - F57A-5B326-GC
H - F57A-5B326-HC
J - F57A-5B326-JC
L - F57A-5B326-LB
1 - F77A-5B326-AGA
2 - F77A-5B326-AHA
Rear Spring Codes/Part Numbers
F - F57A-5560-FD
H - F57A-5560-HC
L - F57A-5560-LC
Mac is offline   Reply With Quote
Old 04-24-2009, 08:00 PM   #9
Graham99ranger
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
cool, i didn't know about the torsion bars either. i think the leaf springs are in alphabetical order going from lowest load range to highest. i think i'll go with a lower one from an explorer, it should still be stronger than my saggy ranger but not ride too rough. if i'm wrong please don't hesitate to tell me.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
