| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc. |
Thread Tools | Display Modes |
#1 |
i have a dana 44 6cf front axle in my 75 f-250 highboy. i need the outer axle. i cant find the date on the axle. truck has disc brakes on front with ball joints. would it be safe to order from lmc a axle for a 77 model? any and all info is greatly appreciated.
Tweet
#2 |
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: dripping oil in driveway
Rep Power: 13 ![]() iTrader: (3)
http://77cj.littlekeylime.com/images...hafts_Ford.gif
this should help you out
__________________
Only a Southerner still calls that domestic conflagration of the 1860s, "The War of Northern Aggression" |
Tweet
#4 | |
Quote:
Tweet
#5 |
Year: 97,79,00,72,71
Make: Ford
Model: Ranger, F250, F350, Mustang, Bronco
Engine: 3.0, 460, 7.3psd, 351c, 351w
Class: little bit of everything
Used For: waste all my money
Rep Power: 11 ![]() iTrader: (68)
If its a disk axle, its either 76 or 77. It's a 44 HD if its got big hubs that are over 4" in diam. That shaft should be the same as a regular 44 I'm told. I havent checked this. I have a stub shaft from a regular 44 I'd sale for $25 shipped if you want try it.
__________________
97 Ranger 3.0 5spd 1354m disc 8.8 00 F350 Dually Crewcab 4x4 7.3 6spd 79 F250 501BBF,4spd, d60, 10.25 38s 72 Mustang Mach1 351C, 4spd 71 Bronco d60, 14bt, 351efi, 4spd,203/205, 44s beadlocks plus lots more |
Tweet
#7 |
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: Everything it works for
Rep Power: 9 ![]() iTrader: (0)
if its an apen knuckle disc break high pinion axle its from a 77.5 to 79 and you need this shaft. The later open knuckle hd axles did NOT have the big lockouts but rather standard 1/2 ton lockouts the 77 hd shaft wont work because it has a larger u joint whereas the 77.5 up has the 760x joint. easy way to tell is open or closed knuckle that is the main difference. this only applies to 8 bolt axles though.
sources for shafts and other parts: http://broncograveyard.com/bronco/c-400 they have oem dana shafts/parts http://completeoffroad.com/c-59880-dana-44.html good selection and the only chromo set ive seen made specifically for this axle\ Oh and upgrade to the 760 joint while its out Hope that helps -Evan
__________________
It may be silly...but aint it fun 1989 Ranger, 2.9 5-spd, Under going d44 spartan/ d60 welded 4.10s and 36s (Build Thread) |
Tweet
#9 |
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
just makin sure cause parts aint cheap
__________________
Tweet
#11 |
need a stub axle for a 44 6cf . found it at bronco. it uses the 760 joint . 760 joint wont work with stock axles, sowhat do i do to make the stub fit my stock long axle? thanks much
lmc offers the axle assembly for the 44, but doesnt say if its the hd or not. will it work? Last edited by minerman; 04-14-2009 at 10:38 PM. |
Tweet
#12 |
thinking about going with new alloy axle shafts from offroaddesign.com. i have a d44 6cf front in a 75 highboy. wondering about you guys opinion. going to go with 760 joints. will the new axles go right into my housings with no changes? if i can jerk my axles out and slide the new ones right in, IM GETTING EM. no mechanic here. i figure it this way, i bought this truck about 2 mos ago, i now have a bad yoke on my stub, rather than do this again, and continue to have the downtime and cost of smaller axles being broken, i'll buy the best i can afford NOW. please advise me in the way i should go. thanks in advance. remember, i'm no mechanic, so keep it in laymans terms
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
