aftermart fuel cell and external pump wiring help
thelowranger
10+ Year Member
im looking for some help on hooking up my first fuel cell and choose to go with a fuel cell with a built in sender and going with external fuel pump. I am trying to find out if i can use any of the factory wiring or if i have to run all new wiring. appreciate any help
1999 ford ranger 3.0L ,RCI fuel cell
got any plans on a what pump your running? I dont think youll need a whole lot of volume just need to get the pressure right so you dont have drivability problems. I think the stock regulator might work. I would just use the existing wiring because you will probly have the pump close to the stock position. Just curious as to why and where you are putting the fuel cell. you would be looking at a pump like this http://store.summitracing.com/partd...925239+4294839053+4294836965+115&autoview=sku
and they have wiring kits also
http://store.summitracing.com/egnsearch.asp?N=700+4294925239+4294839053+115+4294805528
so do some research and figure out what psi you need and go from there
