Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 03-27-2009, 07:20 PM   #1
Dweano
Dweano's Avatar
Year: 1996
Make: Ford
Model: Ranger XL
Engine: 4.0L
Class: 4x4
Used For: Daily Driving/Off-Roading
Dweano will become famous soon enough
Default Temperature Problem? Whats going on here?
Alright, awhile ago i was driving to school, temp gauge started as low as she goes like usual, then warms up to "normal" (about 1/3 of the gauge), then all of a sudden it warms right up to about half of the gauge and I'm like oh dang, contemplating pulling over...then all of a sudden bam, its down to a little bit below normal...and not slowly...it took about twenty seconds to go from "half the gauge" warm, to about "one quarter the gauge" warm. So it warmed up and cooled down randomly really fast. And it happened a few times, but about after ten mins everything was normal and it stayed normal. After school it happened a bit too. Whats going on here? And its not like I gunned it and kept it revved for a long time, i was cruising along at a constant speed and rpm. I also get pretty crappy mileage which may or may not be related.
Dweano is offline   Reply With Quote
Old 03-27-2009, 07:22 PM   #2
99RangerBoss
99RangerBoss's Avatar
Year: 2003
Make: Ford
Model: Ranger edge 2wd
Engine: 3.0
Class: 2WD Off-road
Used For: drifting, racing ricers, etc...
99RangerBoss is on a distinguished road
Default
sounds like a head gasket check out your oil and or your oil filler cap for white oily sludge kinda like a milk shake
__________________
DISCOVERY 31'sx10.5, Dixon Bros front tube bumper, Pioneer Deck, Hurst Billet Plus Shifter and T-Grip Handle, 2-1/2" exhaust with Warlock Muffler, AR 15"x10" rims, Beltech Shackles, T-Bar crank!
99RangerBoss is offline   Reply With Quote
Old 03-28-2009, 12:23 AM   #3
Dweano
Dweano's Avatar
Year: 1996
Make: Ford
Model: Ranger XL
Engine: 4.0L
Class: 4x4
Default
Awe damn, i was hoping it wouldn't be that. How major of a fix would a headgasket be?
Old 03-28-2009, 01:43 AM   #4
fordboi415
fordboi415's Avatar
Year: 2001
Make: ford
Model: ranger
Engine: 3.0V6
Class: 2wd offroad
Used For: haul dirt bikes, and play in the mud
fordboi415 is on a distinguished road
Default
Could also be a bad t-stat sounds like its sticking closed then openeing, would be worth the 10 bucks to repolace it
__________________
2001 Ranger XLT 3.0L 2WD camburg 5.5
f31 deavers 33" maxxis buckshot
1059 pro comp wheels
Fox Shox/Premeir Pioneer sound system
http://www.cardomain.com/ride/2978855
fordboi415 is offline   Reply With Quote
Old 03-28-2009, 10:34 AM   #5
SoLongStang9499
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L 245CI
Class: 4x4
Used For: Daily Driver
SoLongStang9499 is on a distinguished road
Default
It sounds like its just your thermostat opening and closing, usually it opens and closes very fast preventing from seeing any variation you've described. If it was cold outside it just may be your cooling system not staying up to temp due to the cold. To check this, when your temperature gauge starts to stay normal, turn on your heater on low but on full heat, If it falls again and then raises again, its completely normal. Your thermostat will ( and should only) open at i think 192 degrees I believe in stock form. So if your thermostat is opening, cooling the system to below 192 degrees, the thermostat will close. If its cold outside the cooling system would have more cooling capacity, and drop the temperature even lower when the thermostat opens, which would take some time for the system to heat up again to 192 degrees, which I think thats what your seeing.
__________________
1999 Ford Ranger XLT 4.0 5 speed, Magnaflow Dual SS Exaust,Upper end rebuild at 88k miles, Lund bed cover, custom Vaccum gauge setup on A-Pillar
89k miles
SoLongStang9499 is offline   Reply With Quote
Old 03-28-2009, 12:47 PM   #6
Dweano
Dweano's Avatar
Year: 1996
Make: Ford
Model: Ranger XL
Engine: 4.0L
Class: 4x4
Default
Phew, I'm hoping its just the thermostat, this would make sense actually because the older man i bought it from said he replaced the thermostat himself, so he could've got a cheap quality one, or installed it wrong or something. I'll look into replacing the thermostat.
Old 03-28-2009, 04:35 PM   #7
SoLongStang9499
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L 245CI
Class: 4x4
Default
I really dont think you need to replace the thermostat either. If its heating up to norm temp, then cooling down below that, why would you expect your thermostat is malfunctioning? If anything, it seems your cooling system is functioning more effectiently then it needs to, thats just how i see it.
__________________
89k miles
Old 03-29-2009, 04:22 PM   #8
Dweano
Dweano's Avatar
Year: 1996
Make: Ford
Model: Ranger XL
Engine: 4.0L
Class: 4x4
Default
It goes above what it normal was running at before, it used to run at a third of the gauge and when its jumping around it goes up to half the gauge or more. And its very erratic so something just doesn't seem right.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
