| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
BRAKES GRIND when you come to a stop. I have replaced the rubber lines in the front as the rotors, pads, and bearings were already done. When i replaced the lines it stopped for 2 days and now it is back. Should i go ahead and replace the pads,bearings, and have the rotors turned again.I do not want to do this if this is not the problem. Any help would be great.
Tweet
#2 |
Einstein I'm NOT
Year: 1988
Make: Ford
Model: Multi-year Ranger
Engine: 2.3 Carbureted
Class: 2wd
Used For: Space travel
Rep Power: 76 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
if you've replace all that and it's still grinding, check that the backing plate is clearing the rotor...you may not hear it so much at higher speeds but it's noticeable at lower speeds...or does it only happen when you engage the brakes?
Could also be the rear brakes...
__________________
Rome and my Ranger were not built in a day... |
Tweet
#3 |
Only when you engage the brakes.The owner before me did the brakes the day before i bought it. I had to what for him to do it to pick it up. I did the rears a month ago thinking that was the problem. It only dose it when the truck is about to come to a stop i.e going very slow.
Tweet
#4 |
Year: 2001
Make: Ford
Model: F-250
Engine: 7.3
Class: 4x4
Used For: Everyday use
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (8)
I have brand new pads and rotors on my 99 and they squeel when I get on the brakes, i've just come to accept that it's metal on metal contact.
Tweet
#5 |
Year: 1998
Make: Ford
Model: Ranger xlt flareside
Engine: 2.5L
Class: 2wd
Used For: daily
Rep Power: 10 ![]() iTrader: (0)
mine is doing the same thing. i don't notice the grinding all the time just like you mentioned. It still stops good and doesn't squeal so I'm puzzled. I am taking mine to the shop next week I'll let you know what they say.
Tweet
#6 |
Year: 1994
Make: Ford
Model: Ranger XLT
Engine: 4 cyl.
Class: 2WD
Used For: Anything I need it for.
I shoot the back of the pads on every brake job I do with CRC Disc Brake Stop Squeak or whatever it's called. The only vehicle I have had continue to make noise after that is my moms '04 Rav4 S that she uses for her mail route, but that one I think is because of the friction compound because the old brakes never made a noise.
Tweet
#7 | |
Year: 2001
Make: Ford
Model: F-250
Engine: 7.3
Class: 4x4
Quote:
Tweet
#8 |
Year: 1994
Make: Ford
Model: Ranger XLT
Engine: 4 cyl.
Class: 2WD
Not to sound like a wise guy here, but I think the saying that comes to mind is "You get what you pay for" so yeah, I agree, price can make a huge difference on parts, lol. What's really odd is the pads on my moms car is they are the Wager Quiet Stops, which if I remember right aren't exactly the cheap ones, but the guy at the store got tired of searching for the record of the old pads on my account (commercial level 4 at Advance, so I've got a buttload of stuff on record there) so he grabbed those and gave to us for warranty.
Tweet
#9 | |
Year: 2001
Make: Ford
Model: F-250
Engine: 7.3
Class: 4x4
Quote:
Tweet
#10 |
Year: 2002, 2005, & 2
Make: All Fords
Model: Ranger Edge '02, Freestar '06 & The newest '05 F150 FX4 SCrew
Engine: 3.0L/4.2L/5.4L3V
Class: 2WD/4x4
Used For: Original Daily Driver/New DD
Rep Power: 9 ![]() iTrader: (0)
I have noticed the grind problem as well (drums - shoe, hardware, & drums itself- replaced Nov 2006 / Front- rotors, bearings, pads - June 2008). I replaced pads with ceramic/metalic composite. At first light breaking would cause squeal. Squeals gone, but firm moderate to heavy slow speed braking I get the grind. I can see no rotor damage, and the pads still have plenty of meat. No heat build up (as if dragging caliper of pad), so I assume it is just the ceramic taking a bite.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
