94 2.3 to a 4.0
lost.idiot
10+ Year Member
my 2.3 just took a dump and i wanted to put a 4.0 into it. my only questions are what 4.0 can i use from what year? what would be the easiest?
The easiest swap would be from a 93 or 94 Ranger.
1). You'll need a complete wiring harness from a 93 or 94 4.0 Ranger. This means the on-engine and compartement harness. Every bit. The explorer's engine compartment is set up differently. It would be a nightmare to try and fit it to your Ranger. Also.....best to use the proper harness for the proper 4.0/auto, or 4.0/MT combo.
2). A 93-94 Explorer or 4.0 ranger PCM. Best that you get a Manual Tranny PCM when using a MT, but you can use a AT PCM. The biggest difference is fuel injector idle down strategy. But you can't use a MT PCM for a AT, as the MT PCM would lack the proper Torque convertor lockup info, etc.
3). It's once again best to get an engine from a 93-94 4.0 Ranger or Explorer. Intake to oil pan. The have the proper sensors and set 90-92 are slightly different and 95-97 are quite a bit different. If you must get a 90-92 4.0, you'll need to swap injectors from a 93-94 4.0. As they changed from a "needle" pintle to a disc pintle style of injector in 93'. But the rest is the same....engine wise.
4). Exhaust: Manifolds will be needed of coarse. You will need a y-pipe from the same years. A 90-92 only uses one HO2S. A 93-94 will use 2. A 95-97 y-pipe has a different flange to catalytic convertor. The fatherest back you should have to replace is to the catalytic convertor. Everything further back should interchange.
5). There are even a few little differences between 93 and 94's. In 94 they started producing 4.0's with CPS's and EGR's. If your donor engine has either of these, then you need a PCM and harness that match. Some 94's have one or the other, both or neither. All depends, but another reason why everything should be taken off the same donor truck.
6). Transmission: You need a A4ld or M5od-r1 from a 4.0 Ranger or Explorer. The Auto's can be gotten from a 90-94 4.0 vehicle and the M50d-r1's can be had from just about any year of 4.0 truck.
6). Other things that may need attention or be obtained are fuel lines, air intake, radiator, and engine mounts.
thanks for all the info it really answered alot of my questions. will the motor mounts need to be swapped out? and where would the best buy, a new one or one from a donor? i know a new one would be great but it is also costly. do u know of a place to get rebuilds or should i just look at my local pick a part?
I'm using motor mounts from my donor.
The engine is best gotten from a donor. As it's usuually cheaper, and everything else can be picked off it.
If you go with a rebuild, just check out your local auto parts store.
Generally speaking the best way t do an engine swap is to aquire
a wreck with the engine you want
Next best is educated junkyard shopping.
Basically if you pull an engine from a vehicle that has "road rash" on the roof the engine is usually good:)
AD
Time to resurrect this thread, Was there ever any clarification on whether or not a 2.3's(1997) manual tranni/flywheel/clutch/starter would work on a 4.0 engine(also a 97' model)?
why would you want to use the 2.3 trans on a 4.0 youll snap that thing like a pretzel with that torque
They can be had for less than 50 bucks locally, and I'm sure they would handle the power all day long. I've seen several turbo'd 2.3's make more power than a stock 4.0 through stock transmissions...
There is no strength difference between any of the Mazda transmissions. The gear ratios are different for the 4.0 version, and the bellhousing (not removable) pattern is different between the 2.3/2.5, 3.0, and 2.8/2.9/4.0 engines.
