Need to find front gear
Zerocide
15+ Year Member
Black Forest, Co
So i know i got a 7.5 in the rear with 4.10 gears. I know i got a dana 35 in the front but am totally clueless on what the gears are. Does it tell me someone on the axle or am i looking for a code chart to compare numbers with.
while im on the topic is there a stronger front axle i could replace the dana 35 with sense i am IFS.
when buying gears, you dont need to know anything more than its a standard cut dana 35. if the 4.10's you have in the back are stock, than you also have 4.10's up front.
there is no bolt in upgrade for the front axle...and the d35 is plenty strong for most gear/engine combos.
