2007 Ranger Blinker Modification
mjonesjr
I dance with the Devil...
Forum Staff - Retired
Firefighter
Salem, IN
Original Poster: The H.P. Freak
Difficulty: _ out of _
Time to install:
As you know the newer Rangers ('02+) only have a turn signal bulb in the front head light assembly. Well this mod turns the corner marker light into a turn signal as well. This mod allowing more visibility of your turn signals to other motorists.
Here's a few pics :
Here is the stock set-up from the factory on the D/S.
The BLACK/YELLOW (black wire with yellow stripe) needs to be cut. Make sure to leave enough wire so that this mod can be reversed if desired.
I used weather tight male/female electrical connectors for a cleaner look plus it would be very easy to return to stock later if I wanted to. The dead end of the wire got a opposite connector, and I simply used another connector to block it off. I then used some shrink tubing to make it water resistant.
Now I took the other end of the wire and tapped it into the PURPLE/GREY (purple wire with grey strip). This would be the bottom wire out of the 3 wires on the turn signal harness with the quick clip facing up.
It should look like this :
This is the finished product after everything was taped back up :
Added to Summer issue.
