| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
I'm looking at installing this MSD ignition in my 1996 3.0 ranger http://www.msdignition.com/ignition_8_6470.htm with the hopes of getting some more low end grunt out of the beast, but I wanted to make sure it was comptible with the motor before i spend the cabbage.
This motor uses waste-spark ignition controlled by the PCM, correct? If so, is this even feasable? Also, upon snooping around the MSD site, i came across a direct plug-in wiring harness for this ignition module for a Ford TFI ignition system. (MSD P.N. 8874) Ford used TFI from the 80s through the mid 90s right? I don't suppose my OBDII controlled vehicle would be lucky enough to have this option right? Sorry for the barrage of questions, but i figured i'd get all of them out in one shot. Thanks for the help guys.
__________________
1996 Ford Ranger 4x4 Superlift 6" lift kit with front 8" Skyjacker coils Belltech Shackles, 6" Skyjacker leaves & Stock Block Front and Rear Lock-Rights and 4.56 Gears 35x12.50r15 M/T Radial Baja Claws Flowmaster American Thunder 2.5" exhaust Enough stereo to make you deaf Enough lights to make you blind Cooler permanently filled with Bud Light "Oh, she goes places!" |
Tweet
#2 |
Year: 2003
Make: FORD
Model: Ranger-SuperCab
Engine: 4.0 SOHC
Class: 4x4
Used For: Riding mad max style......
Rep Power: 18 ![]() iTrader: (38)
Ignition will not change an engines power band. Truthfully, MSD igntion is a waste of money, if you want to spend money on ignition, any low resistance 8mm wires with new autolite spark plugs are good. All that msd is good for is holding down a big stack of paper. The 3.0 is a rever, you really can't change that. Good Luck.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark. Giddywomp Offroad & Fab
Tweet
#3 |
I realize that I will not change the motor's power band, but i was hoping to see a little more power from the MSD. I know its not going to turn this thing into a blown 460 by any stretch of the imagination but I would be happy with even a small gain. I'm just trying to bolt on a few more ponies before i swap up to 35" tires.
And with an ignition would def. come MSD 8.5mm plug wires and new plugs, etc. So anyone know if this thing will work with my truck? Any advice will be greatly appreciated.
__________________
Tweet
#4 | ||
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Rep Power: 25 ![]() iTrader: (0)
it wont work. you need to scroll down further on msd's main page...there is a distributorless ignition section....the 6 cylinder controller starts at about $500
fords DIS is a very effective setup (so much so that msd's DIS controller is actually a slightly modified rip-off of fords design.)...there isnt anything you can do to improve on it. the most bang for your buck would be a tuner from BAMA CHIPS
__________________
As seen on the internets! Quote:
Quote:
Tweet
#5 | |
Quote:
__________________
Tweet
#6 | |
Year: 1993
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 4x4
Used For: Daily Driver
Rep Power: 12 ![]() iTrader: (0)
Quote:
__________________
93 Ranger, 3.0L, 5spd, manual t-case swap, MSD ignition, 31x10.5 BFG AT's, 2006 ranger bucket seats, rancho RS500 shocks, Warn 37780 "Jeep" hubs, 2007 Glasstite Raven Canopy. http://www.cardomain.com/ride/2327329/1 |
Tweet
#7 | |
Year: 2003
Make: FORD
Engine: 4.0 SOHC
Class: 4x4
Quote:
Replacing worn ignition??? Wicked sludge is right when he says ford DIS is very good...and efficient. A programer is a really good idea for an automatic. It'll change your shift points for better accleration.
__________________
Tweet
#8 |
Year: 1993
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 4x4
__________________
Tweet
#9 | ||
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
He means maybe you inadvertently fixed a problem with your stock setup when you installed the MSD.
The distributored ignition is quite a difference beast than the DIS setup. MSD usually provides a little smoother idle and some low end grunt in this setup.
__________________
Quote:
Tweet
#10 |
Premium Member
Year: 1999
Make: Ranger
Model: St. Cab
Rep Power: 18 ![]() ![]() ![]() iTrader: (0)
You can't beat Ford's EDIS! You will be throwing your money away on the MSD!
__________________
"you can rant, rave, scream, shout invective, claim infinite experience, and ultimatly deny that you are wrong until hell freezes, but you are WRONG." Alland |
Tweet
#11 |
Tha factory setup is pretty good as long as it's in good shape and you don't have one of the coils mentioned in the TSB.
__________________
1. MORE COWBELL! 2. Chuck Norris can win Connect Four in three moves. 3. What the H___ is an aluminum falcon!?! 4. sham....WOWWWW |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
