| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1992
Make: ranger
Model: 4x4 single cab stx
Rep Power: 0 ![]() iTrader: (0)
I have a '92 STX 4x4. I bought it used several months ago and don't know the service history. I'm having an issue with my rear drums. If I hit the brakes hard at any speed they lock up. It feels like they are the rear. I only say this because after the hard stop, and I continue driving there is a noticable drag in getting it going. It feels as though the parking brake was left on. I gave the brakes on all four corners the works, because when I started to take things apart brake parts started to fall off. New calipers/wheel cylinders, pads/shoes, discs/drums resurfaced, front hoses. I flushed all the lines while I was at it.
I just took it out for a test spin and I'm still having the problem. It's not as bad. Before I would have to rock the truck back and forth before they freed up. Now they just drag for a few seconds. My question would be: could this be a master cylinder problem? It's about the only thing I havn't changed out. My truck has no ABS. EDIT: Forgot to mention while I was bleeding them the front spouts pumped good. When I tried to bleed the rear they would just trickle. Is this normal for ranger drums? Thanks Last edited by Larue; 03-08-2009 at 08:25 PM. |
Tweet
#2 |
Einstein I'm NOT
Year: 1988
Make: Ford
Model: Multi-year Ranger
Engine: 2.3 Carbureted
Class: 2wd
Used For: Space travel
Rep Power: 78 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I had a similar problem with my Ranger...turned out to be the flex lines...they can, apparently, act like a one-way valve when the inside deteriorates...the brakes lock up because the fluid is not returning to the reservoir and staying in the lines...keeps the brakes engaged...
There have been a few posts on that since...if you haven't replaced the flex lines it could be the problem... As far as the rears trickling, I didn't notice that when I bled the rears because I changed all the lines and connectors...could also indicate the flex line to the rear connector on the axle is NFG...
__________________
Rome and my Ranger were not built in a day... |
Tweet
#3 | ||
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Rep Power: 25 ![]() iTrader: (0)
+1, replace the rear brake hose.
i thought all trucks came with rear-ABS by gen 2...
__________________
As seen on the internets! Quote:
Quote:
Tweet
#4 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
It should have RABS....my 91 does.
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
#5 |
Year: 1992
Make: ranger
Thanks guys. I'll change the hose out when I get a chance this weekend. I wasn't sure about the ABS. I was looking for wheel sensors when I was under there. If there is an ABS unit where would they have stuck it?
Thanks, Larue |
Tweet
#6 |
Year: 1989
Make: Ford
Model: Ranger
Rep Power: 13 ![]() iTrader: (0)
The sensor ring is in the rear axle housing; you can see the pickup for it screwed into the passenger side rear axle. The rabs valve is on the frame rail towards the rear. If your rabs valve is on it's way out the flow through the rear bleeders can be a trickle, or none(which is what I had).
My brakes would lock up on hard braking, mostly at under 20 mph. The problem disappeared after the brake master was replaced.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel. |
Tweet
#7 |
Logan Andrew Feb 17, 2012
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (15)
RABS valve is right under the driver's butt on the inside of the frame rail. I would suspect it being the culprit. There is also a T on top of the rear axle.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
