Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 03-08-2009, 04:17 PM   #1
harriw
harriw's Avatar
Year: 1994
Make: Ford
Model: Ranger XLT, ext. cab
Engine: 4.0L
Class: 4x4
Used For: Daily Driver
harriw is on a distinguished road
Default Paranoid Radiator Question
Hey guys,
Paranoid rookie question - I've got the radiator drained while changing a thermostat ('94 ext cab. 4x4, 5spd behind 4.0 w/ AC), and it's looking like it's going to be a multiple day project.
Any concern over leaving the radiator drained for a few days? It's not gonna start rusting over in there while it's empty for just a few days, right (I suppose I could fill it with distilled water while I'm not working on it, but that's just a pain)? How should I leave it while I'm not there working on it? Draincock and cap both closed, or leave one or the other open?
Thanks a lot guys.
-Bill
__________________
Sorry for the corny avatar - I just happen to work on High Voltage Power Supplies for a living and couldn't pass it up.
harriw is offline   Reply With Quote
Old 03-08-2009, 04:35 PM   #2
martin
Year: 1984 1991
Make: ford
Model: b2 explorer
martin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the rough
Default
It won't make much difference, as long as you don't leave any liquid in it that will freeze, if it's being left outside.
martin is offline   Reply With Quote
Old 03-08-2009, 04:35 PM   #3
86ford
86ford's Avatar
Year: 1992
Make: FORD
Model: Exploder
Engine: 4.0, abused and misunderstood
Class: 4x4 locked
Used For: creating a need for a larger broken parts bin
86ford is on a distinguished road
Send a message via AIM to 86ford
Default
Filling it with water only WILL blow freeze plugs in the motor if it drops below freezing for any significant period of time. Motors sit on engine stands for YEARS with no coolant in them. I can not come up with a single concern with leaving it empty.
86
86ford is offline   Reply With Quote
Old 03-08-2009, 04:36 PM   #4
Bent Bolt
Bent Bolt's Avatar
Year: 1987
Make: Ford
Model: Ranger STX
Engine: Supercharged 4.0 SOHC
Class: 4x4 Offroad
Used For: Breaking parts , sitting in the back lot
Bent Bolt is on a distinguished road
Default
It's fine empty.
__________________
87 Ranger , a bunch of stuff including a supercharged 4.0l SOHC and 35 x 14.5 x 15 Pitbull Maddog's. Woof !
Now with C5/C4 hybrid !
Bent Bolt is offline   Reply With Quote
Old 03-08-2009, 04:38 PM   #5
harriw
harriw's Avatar
Year: 1994
Make: Ford
Engine: 4.0L
Class: 4x4
Default
Excellent - thanks guys.
-Bill
__________________
Old 03-08-2009, 10:48 PM   #6
Nhaz
Nhaz's Avatar
Year: 1998 and a few
Make: Ranger+Ranger+E
Model: XLT + XL
Engine: 4.0 3.0
Class: 4x4
Used For: 2500+ kilometers a month
Nhaz is on a distinguished road
Default
Never use pure distilled water in a antifreeze system. ever. Good for batteries. bad for Engines => Heck tap water is better then distilled.
And you shouldn't use pure tap water either => Distilled water is more reactive then regular water since its had most of anything its allready reacted with it Removed in the distillation process. which makes it so it will start eating things it comes into contact with.
Like engines. Not quickly but definitely. The only thing you should put into your coolant system is coolant or premixed coolant.
__________________
Damage to the Mercedes that cut me off. front end Gone : cost $8000+
Damage to my truck ..my tire bead. Cost. $20 to pull the tire off and reseat it. it was leaking air
Nhaz is offline   Reply With Quote
Old 03-08-2009, 11:12 PM   #7
warrior24
warrior24's Avatar
Year: 1992
Make: Ford
Model: Ranger SuperCab
Engine: 4.0
warrior24 is on a distinguished road
Default
Hmm I don't always use distilled water but I thought you were supposed to use it. Here is what I found , now I am confused.
http://answers.yahoo.com/question/in...1230644AAbCqcE
__________________
I'm not asking you to fix it, just please let me get it back to the way it was before I touched it.
The Technician Prayer
warrior24 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
