Project PaleBlue
PaleBlue90
15+ Year Member
Boosted (Not Stock)
Solid Axle Swap
Aurora Colorado
the start
Project PaleBlue
Project PaleBlue
Project PaleBlue
Project PaleBlue
Project PaleBlue
Project PaleBlue
heres my new Rustys Hi-Steer kit for jeeps
Project PaleBlue
Posion Spider Customs LEDS mounted
Project PaleBlue
seems like a kilelr start, why did you go with the leafs?
i went with leafs beauce they were easyer to work with IMHO, i also want to be diffrent:icon_welder::icon_hornsup:
if i didnt move it forward the transmission crossmember would be in the way, so i had to move it forward so i could weld my spring hanger to the frame
looks cool what axle did you use up from whats it from im going to be doing this swap soon and i would like to know what you used thanks ahead of time
i used a jeep yj dana 30, im useing stronger axles and a ox locker with 4.10's. i got the axle without knuckles or axles for 20 bucks...the best part though is its a HI-Pinion dana 30:clapping:
Hows come u dont take the bed sides off and make a cage for yer spare and a high lift and anything else you want to take with you to the trail?
sounds good, does it have a transfer case on yet? or is it still 2wd
