89 prerunner
dirtdigr27
15+ Year Member
what size tires can i run on my truck w 3in body lift 1.5 leveling kit and HD leafsprings and fender and bedside fiberglass:headbang:
if you are turning your truck into a prerunner loose the bodylift, with flared and bulged fiberglass fenders and bedsides and a leveling kit you can run 33's. your gonna loose flex with HD leafsprings, you dont need deaver springs to have fun a local spring shop can make you a set of springs for cheap that will flex and give you the lift you need, I would also flip your rear hangers and shackles for better travel
so i can just put and leviling kit and bulged fenders and bedsides and clear 33's...will they rub anything???...what would be a good set of leafs to put on it, keeping in mind that its my DD for now
I'm not 100% sure, but from how the article reads its sounds like project pre rocker was a highrider truck. And I think this makes the 33's possible with out rubbing off road on the firewall with no lift.
"just a spring shop" wont have as good of spring as deaver if your looking for a "prerunner truck" pack unless they have been working with the desert truck's for awhile.Bit for a trial truck flex pack Im sure there are a large number of springs shops that could be up to the job.
also if you want the pre runner look, start, skip the body lift like FX2 said
I didnt say that "just a spring shop" would make a leaf pack near the quality or the ability of a deaver spring but unless you are looking to build a race truck or a true prerunner a good spring shop can make a leaf pack that will perform quite well and meet dirtdigr's needs
