| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
Year: 1998
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4 body lift
Used For: Everyday use
Rep Power: 9 ![]() iTrader: (0)
I have a 98 ranger 4x4 ext cab and I have a set of 32x11.50s and currently running a 7 inch wheel. I have found some 15x10s I like alot. Im unsure of the correct backspacing they have but this link is identical to them. http://www.misfitsoffshore.com/phpbb...ife_ph_126.jpg
With those rims would I have to trim anything? |
Tweet
#4 | |
Year: 1991
Make: ford
Model: ranger-needs more lift
Engine: 4-0 swap
Class: 4x4
Used For: work and play
Rep Power: 16 ![]() iTrader: (7)
those rims are way to wide for a tire thats actually 9 inches wide.they are barely narrow enough for a 12.5 wide(actually 10"s) tire. use 3.75 backspacing on any new wheel(its factory spec and works best)
__________________
4.10's, 33's, duff stage 3 w/4" coils, cb,cowl snorkle, homemade high clearance d-ring bumpers,bobbed bed,8.8 My bobtail beater Quote:
Tweet
#5 |
Year: 2003
Make: Ford
Model: ranger xlt
Engine: 3.0
Class: 2wd
Used For: daily driver
i ran a 11.50 tire on a 10 inch rim for 3 or so years. dont know if it affected anything on my truck. but it worked. and looked badass!!
__________________
2003 xlt. ext cab. 3.0 , K&N HAI, DynoMax cat back exhaust, Yukon 4.56s, Ford Traction Lock, 15x8 Xtreme alloys, 30x9.5 pro comp all terrains. |
Tweet
#6 |
Year: 2003
Make: Ranger FX4 Leve
Model: Ranger
Rep Power: 12 ![]() iTrader: (0)
i currently am running a 32x11.50 on a ten inch rim with out rubbing all i have is a t-bar crank on my 03 level II. I have was running 33x12.50 on them but they rubbed the lower valance at full lock. I am not sure of the back spacing on the rims.
Tweet
#7 |
Junior Member
Year: 1998
Make: Ford
Model: Ranger
Engine: 4.0
Ok I do have a 3 inch body lift. Torsion bars cranked to level the truck. I late have plans on fully cranking and adding a leaf or lift shackle to the back.
Theres no problem running that tire size on a 10 inch rim my buddy has a 31x10.50 on a 10 inch rim and he didnt have any bad wear out of them except the back passenger side(LOL). I was mainly concerned about fender trimming and im not a fan on that unless its a beater. Thanks for the help because im going to try to get them if the price is alittle negotionable. haha |
Tweet
#8 | |
Year: 1993
Make: Ford
Model: Ranger xlt supercab
Engine: 4.0L V6
Class: 4x4
Used For: Daily Driver, desert toy
Quote:
so your buddy is running 10.5 tires on a 10 inch rim, correct? in your opinion, do you think the same concept would work for 12.5 tires on a 12 inch rim? everyone has been telling me that its not a practical combo, and i get that. but i have a set of 15x12 eagle alloys and the largest tire i can run on my truck is 33x12.5x15. possible? what about a 31x11.5x15 tire on that same 15x12 rim? |
Tweet
#9 | |
Year: 2003
Make: Ford
Model: ranger xlt
Engine: 3.0
Class: 2wd
Quote:
__________________
2003 xlt. ext cab. 3.0 , K&N HAI, DynoMax cat back exhaust, Yukon 4.56s, Ford Traction Lock, 15x8 Xtreme alloys, 30x9.5 pro comp all terrains. Last edited by dru; 02-23-2009 at 10:53 PM. |
Tweet
#11 | |
Year: 1991
Make: ford
Engine: 4-0 swap
Class: 4x4
BAD IDEA
you don't want a wider rim than the tire contact area,it looks gay and will aggrevate sidewall and rim damage. refer to my siggy quote by critter.you need gold spokes and whitewalls take a tape measure and see for yourself.you want the so called(its actually two inches narrower than it says) tire width to be two inches wider than the rim to be matched well.i don't know why they do it but the width is two inches less and the height is usually about 1.5 inches less than stated on the sidewall. if you think a 10.5(8 inches wide) fits on a 10 inch rim you've got some learning to do still. an 8 inch rim is perfect for 10.5's and 11.5's. and a lot of guys run them on 12.5 tires on the trail for best performance.my 33x14 boggers say right on the sidewall to use a 10" rim and a 10" rim is about perfect for a 33x12.5 a/t.
__________________
Tweet
#12 |
Junior Member
Year: 1998
Make: Ford
Model: Ranger
Engine: 4.0
Man I know im not crazy and im like a brother to this kid. He ran a 31 10.50 mud king on a 15x10 inch wheel and he got about 30000 miles out of them and no funny wearing was noticable except the back tire and thats because he was gas happy. The front tires had less then 1/4 tread but the tread was flat.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
