Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Non-Ranger Axles
Notices
Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc.
Post New Thread Reply
Thread Tools Display Modes
Old 02-17-2009, 08:34 PM   #1
revetsranger
Year: 91 Ranger xtra-
revetsranger is on a distinguished road
Question Axle Swap
When swapping a 95+ explorer Rear axle with the disc brakes
Are the explorer axles 1.5 " wider on both sides for a total of 3" wider or 1.5"wider overall??
And do I need to add wheel spacers in the front or change the wheel off set??
I weld for a living so relocating the spring perches and the shock mounts should not be a problem.
91 Ranger extra-cab 4.0 V6 Auto /2' body lift /Fiberglass front fenders/31-10.50-15
Thanks for all the info so far !!!
revetsranger is offline   Reply With Quote
Old 02-17-2009, 09:00 PM   #2
BeaterMan
BeaterMan's Avatar
Year: 1985,1997
Make: Ford
Model: Ranger, f150, bronco
Engine: 2.8, 4.6, 5.0
Class: 4x4
Used For: beater/ dd/ donor
BeaterMan is on a distinguished road
Default
it's 1.5 per side if i recall. yes the back wheels will sit further out then the front, at least mine did.
BeaterMan is offline   Reply With Quote
Old 02-18-2009, 08:01 PM   #3
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
The Explorer axle is 3" wider overall than a '91 Ranger axle (59.5" vs. 56.5" WMS-WMS).
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 02-23-2009, 04:09 PM   #4
crawlin91
I ain't got time to bleed
crawlin91's Avatar
Year: 91,92
Make: Ford
Model: Ranger
Engine: 2.9, 4.0
Class: 4x4
Used For: running stuff over
crawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud of
Default
you dont need wheel spacers, but it does sit a lil wider
__________________
RMR '92
crawlin91 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
