Stuttering/Hesitation/Backfire - Finally Fixed!
indyrob
10+ Year Member
2003 B2300 2.3L
I'd been fighting a random on/off-again hesitation, and sometimes backfiring on takeoff after a long period of idling or when the truck warmed up. Sometimes when I'd be driving down the road and give it some juice it would bog waaay down and I'd have to ease up off the gas and just barely give it some throttle to get back up to speed.
I cleaned and replaced all sorts of things like the MAF, O2 sensors, PCV Valve, Coil (x2), Plug Wires (x2), Plugs (x2 and gapped over and over again), Air Filter, IAC, temp sensors, thermostat and fuel filter to name a few.
Every time it would get bad enough for me to pull it in the garage (because by this time I was pretty much used to it) I would replace something and it may or may not go away. Eventually my gauges started acting funny too.
Finally... as I was contemplating a new fuel pump and gas tank my alternator died.
Guess what? The alternator fixed the problem. Unbelievable how much money I threw at that problem... so I hope this helps somebody else. It's been running longer and better than it has in a loooong time. I kinda feel stupid about not looking for an electrical issue.
Rob
BTW... the water pump listed on Autozone's website for the 2003 2.3L engine is incorrect. It's the 2.5L one. The 2005 2.3L water pump as listed on their website is the right one for the '03 and it's about $30 cheaper.
