Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 02-13-2009, 12:44 PM   #1
pacepace87
Year: 2002
Make: Ford
Model: Ranger
pacepace87 is on a distinguished road
Default 351W conversion
I am building a 351W EFI out of a 94 f150 and plan on putting it in a ranger. I was wondering what modifications I will need to do other than the heater box, headers, and beating in the firewall a little for the transmission. Does anyone know of a place that makes headers that will clear and what engine mounts are the best to use to bolt on to existing ranger mount without welding. Also, what is a good 5 speed transmission to use in it.
pacepace87 is offline   Reply With Quote
Old 02-13-2009, 04:39 PM   #2
Beanmachine7000
Beanmachine7000's Avatar
Year: 1991
Make: Ford
Model: Explorer Sport
Engine: 4.0L
Class: Soon to be 4WD
Used For: Soon to be work truck...
Beanmachine7000 will become famous soon enough
Default
Quote:
If you're thinking of streeting it at all go for a ZF 5-speed, everything else, just search for...
__________________
1991 Explorer Sport 4.0L - 167k - DD/Work Truck
"The constitution gives us all the right to be stupid... It's a treasured American right." - Phillip R. Kemmerly Ed.D
Beanmachine7000 is offline   Reply With Quote
Old 02-14-2009, 11:14 AM   #3
alcatrazhotel
Year: 1999 2wd, 1986
Make: ford
Model: all rangers,
Engine: 4.0 , 2.8, 5.8
Class: all of the above
alcatrazhotel is on a distinguished road
Default
i got mounts and blocks for the engine from james duff , i only had to drill one hole in the frame, and they have front to back and side to side adjustment
alcatrazhotel is offline   Reply With Quote
Old 02-14-2009, 11:33 AM   #4
Mac
Premium Member
Mac's Avatar
Year: 2003
Make: Ford
Model: Ranger XLT Ext Cab
Engine: 3.0
Class: 2WD Street
Used For: Summer Beater
Mac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond repute
Default
This going in the 2002 I see listed? This would determine a lot. Coil or torson bar suspension? I'd forget about the ZF for the street, it has a first gear of approx 5.13:1 turning it into basically a four speed for normal use. If you're planning on power output, go with either the Tremec 500 or 600 (or a G-Force modified T-5). Header selection probably comes down to custom. Motor mounts also depend on what you're putting this in.
Dave
Mac is offline   Reply With Quote
Old 02-14-2009, 03:35 PM   #5
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
Forget the ZF for the street, has a deep first not to mention you will need to cut a huge hole in the floor for it to fit properly. Give a little info on the truck so we can help you more.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 02-14-2009, 04:36 PM   #6
1badexplorer
1badexplorer's Avatar
Year: 97,79,00,72,71
Make: Ford
Model: Ranger, F250, F350, Mustang, Bronco
Engine: 3.0, 460, 7.3psd, 351c, 351w
Class: little bit of everything
Used For: waste all my money
1badexplorer is on a distinguished road
Default
Is it 2wd? Run a M5OD out of a 2wd truck
__________________
97 Ranger 3.0 5spd 1354m disc 8.8
00 F350 Dually Crewcab 4x4 7.3 6spd
79 F250 501BBF,4spd, d60, 10.25 38s
72 Mustang Mach1 351C, 4spd
71 Bronco d60, 14bt, 351efi, 4spd,203/205, 44s beadlocks plus lots more
1badexplorer is offline   Reply With Quote
Old 02-15-2009, 09:50 PM   #7
Beanmachine7000
Year: 1991
Make: Ford
Engine: 4.0L
Default
I was thinking 4x4, I'd go T-5 for a 2wd... I didn't know the M50D-R2 bolted up to the 351W... If it does, then that would solve all the problems there...
__________________
Old 02-16-2009, 09:22 AM   #8
1badexplorer
Make: Ford
Default
Quote:
Yea a M5OD is the same from a 300, 302, 351 the only difference is the flywheel they are motor specific I found that out the hard way lol
__________________
Old 02-17-2009, 12:39 PM   #9
Beanmachine7000
Year: 1991
Make: Ford
Engine: 4.0L
Default
Quote:
Well, then I'd change my suggestion to a M50D-R2...
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
