| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1993
Model: Turbo Ranger
Engine: 2.3
Class: 2wd
Rep Power: 0 ![]() iTrader: (0)
My ABS light is lit and when I pull the codes I get code 12 which I believe is brake fluid level low. WHen I check the fluid level visually, it is fine. I am assuming that the sensor has gone bad and have researched it and as far as I can tell, The sensor isn't available without purchasing the entire master cylinder.
Therefore, I would like to bypass the sensor so the reservoir appears to be full to the ABS system. The sensor has three wires coming out of it, one of which appears to be a ground. Does anyone know how to wire them up to bypass the sensor? Thanks in advance. |
Tweet
#2 |
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Ford will sell you an new one. It DOES NOT come with a new MC.
It slips into a tab locked slot on the underside of the plastic MC reservoir. I see that disconnecting the switch will work if you jumper the two pins together that aren't black. Black is the ground wire. This is a Power Supply to your ABS, so insulate that jumper from any metal or it'll blow a fuse. If you simply cut the black wire, it will accomplish what you want, leaving the switch installed and connected. I suggest you disconnect it and jumper the two (not black) wires together and make sure this is your problem before cutting or splicing any wires. (That's another option, cut both (not Black) wires and splice them together). Welcome to TRS. Last edited by Earl43P; 02-12-2009 at 02:53 PM. |
Tweet
#3 | |
Year: 1993
Model: Turbo Ranger
Engine: 2.3
Class: 2wd
Jumpering the two non-black pins together did in fact clear the error code. Thanks.
Quote:
Tweet
#4 |
Year: 1998
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: DD / FUN!
Rep Power: 0 ![]() iTrader: (1)
My truck was doing this. After unplugging and cleaning the connector good it was fine. Also seen the float stuck at the bottom before too...
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
