| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1986
Make: Ford
Model: Ranger
Class: 4x4 Extreme
Used For: Extreme Offroad
Rep Power: 0 ![]() iTrader: (0)
I wanted to know what fuel pump should I run with my 302 swap in my 86 ranger. Its carbureted, and wanted to know if any ones ran the Holley Truck Avenger carb?
Tweet
#2 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
If you are working on previously FI truck, then you can just get a pressure regulator with a return line. Or you could take the tank pump out and get any ole electric pump or an inverted manual pump from a E-Van.
Yes there are some on here that run the avenger carb.
__________________
My Website |
Tweet
#3 |
Year: 1986
Make: Ford
Model: Ranger
Class: 4x4 Extreme
Well i am trying to find a Truck Avenger carb but I can't find one for a 302 so wanted to know where is the best place to pick one up
Tweet
#5 |
Year: 1984
Make: Ford
Model: RANGER
Engine: 5.7
Class: 2WD STREET
Used For: BUILDER
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
and personally i would recommend an edelbrock carb. i love how they run on my cars, easy to tune. and so easy to work on. but thats just my opinion
Tweet
#6 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
Check out this page.
http://store.summitracing.com/egnsea...0+115&x=22&y=5 Holy crap carbs are getting expensive.
__________________
My Website Last edited by v-8power; 02-12-2009 at 06:44 PM. |
Tweet
#7 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Rep Power: 15 ![]() ![]() iTrader: (2)
If you aren't going to add a lot of engine mods the edelbrock is pretty decent, pretty much drop on, set the idle and done. If you add some go fast parts it will then plague you forever. The pump will depend on your engine requirements. A decent stock engine you can use the stock system with a proper return regulator or the econoline pump. If you are building a monster you will need a good electric pump and proper regulator.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
