| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
A friend of mine and I are in the process of installing a 5.0 liter Ford engine in a 1985 Ford Ranger. To ease the installation process we thought we would remove the front clip/core support from the truck down to the frame. After removing the old V6 we noticed that it appears that the grill and fender inner liners are spot welded together. Has anyone experienced this and if so do you have any suggestions on the best approach for removing the clip/support.
Tweet
#2 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
I was going to do this as well. I decided against it because there is like 33 spot welds or something like that. Also there are 2 bolts where it sits on the frame.
If you do it just get a spot weld cutter and go at it. I bought one for less then 20.00 then i bought some replacement cutters for 17.00. Make sure you go slow with your drill. Good Luck with it.
__________________
My Website |
Tweet
#3 |
Year: 1993
Make: Ford
Model: Ranger XLT
Class: 4X4
Used For: DD, Wheeling,
Rep Power: 0 ![]() iTrader: (0)
lemmie know how that works out for ya, im replacing my rad support
__________________
" MAKG-If you're making a snorkel, you don't need anywhere near 3 inches. You're not going to be running drag races in a river" 93' EXT,on the second 302H.O 3" single exaust,Deltaflow 40/AOD/13-56/F-150 coils, Explorer/ranger leafs. |
Tweet
#4 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Rep Power: 15 ![]() ![]() iTrader: (2)
Been there a few times. Most times the core support on these are rotted away and need replaced. That's one thing you need to check, that will decide your plan of action. You don't "need" a spot weld cutter to remove the core support, a regulard drill bit will work too. It takes a little longer though. If you need to replace the core support the way to go is use a grinder and grind the spot welds away. This leaves the fender support with no holes so then you can either spot weld, drill holes for bolts or weld the new support on however you please. I bolt my core support on due to when I need to pull the engine I pull the core support and pull engine and trans in one shot. I can have the drivetrain gutted in about an hour this way. Check to see how rusted the one you have is, if it isn't bad just drill the spot welds and bolt it back on.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works |
Tweet
#5 |
Year: 1995
Make: Jeep
Model: Grand Cherokee
Engine: 5.2
Class: 4x4
Used For: haulin' groceries & wheelin'
Rep Power: 12 ![]() iTrader: (0)
I'll have to ask my dad how we replaced the rad support in my old 88 BII...I think we rivited it back in...
__________________
RIP Matt C - turbonator/sohc86 :( Switched to the dark side - 95 ZJ 5.2 with some stuff..... "I don't break shit, I just test it's durablity" Formerly GONRACIN, Member #166, Join date 30-July 04 |
Tweet
#6 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
I wouldn't use rivits. They are not nearly as strong as a bolt or a weld. Not that you would want it to happen but if you were in a crash rivits will shear quite easily. I rivited my fiberglass bedsides on because they looked cleaner than bolts. After a few weeks the rivits started breaking and eventually I bolted them on.
Matt
__________________
Tweet
#7 | |
Year: 1995
Make: Jeep
Engine: 5.2
Class: 4x4
Quote:
I realize that. My old BII has gone the way of the junkyard now, so now worries about that for me. I'm just saying I think that's how we did it...
__________________
Tweet
#8 | |
September STOTM Winner
Year: 1998
Make: Ford
Model: Ranger
Engine: 4.6 dohc
Class: 2WD Street
Used For: taking up garage space
Quote:
What an awsome idea! I need to replace the core support on my '98. Being able to remove the core support would really help with pulling/installing the 4.6 dohc. Thanks for the great idea. Greg
__________________
1998 Ranger 2WD - 4.6 dohc, Ford prototype intake, custom headers, 4R70W trans, 8.8 rear, 4.10s, trac-lok, aluminum drive shaft, Lakewood traction bars,Mark VIII guages, Explorer buckets, Mark VIII shifter, rear auxiliary fuel tank (no midship), relocated fuel door, fiberglass tonneau cover http://281ranger.homestead.com http://www.cardomain.com/ride/2052265 |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
