Torque specs
Ranger5.0
15+ Year Member
Lindsay Ontario
Hey guys, so the new long block is hear. I am in need of some torque specs:
Oil Pump to block bolts?
Intake manafolt to heads?
Flexplate to Crankshaft?
Also, i got some sensless paperwork with this thing, and it gives me two fireing orders..... the HO fireing order is 13726548 is it not?
oil pump to block--40 ft/lbs. Intake to heads with aluminum intake and/or heads---15 to 20 ft/lbs (torque all bolts in sequence at least 5 times, letting them settle between rounds) Flywheel/flex bolts are 85 ft/lbs. Use thread sealer if it's a 50 oz/in balance crank, the bolt holes go all the way thru to the crank case side.
