- Dec 5, 2007
- 4.0 V6
- Automatic
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 31x10.5x15
- My credo
- Your character is demonstrated by your actions if you knew no one would ever discover them.
Hillary leaks coolant at about 1 pint/minute after I fill radiator and overflow, engine not running.
Leak seems to come from above water pump.
Upper/Lower rad hoses ok; heater hoses ok.
No coolant in oil; no telltale signs of cracked head exhaust sounds.
No coolant coming out of weep hole on water pump, and shaft does not move in its bore and rotates smoothly.
WTF? Any ideas of leak location, or how to locate it (flourescent die?)
