| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#2 |
Year: 2006
Make: Ford
Model: F250 FX4
Engine: 6.0L Powerstroke
Class: 4x4
Used For: Droppin panties
Rep Power: 17 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
...Do you mean 3.0L? I really don't think you will have to raise the engine or remove the pan to change the oil. I know my 3.0L has the plug in the very rear of the pan so I usually lift the front with a jack until the suspension extends. This usually gives a good angle to drain.
__________________
2006 F250 Super Duty Fx4. 6.0L powerstroke ARP studs, EGR delete, 4" turbo-back, bullydog intake, SCT livewire TS with looney tunes... (sold) SUPERCHARGED 2005 Ford Ranger |
Tweet
#3 |
Year: 1994
Make: Ford
Model: Ranger Super
Engine: 4.0
Class: 4x4
Used For: Daily Driver/Toy
Rep Power: 12 ![]() iTrader: (0)
are you tryin to change fluid in the engine or tranny its a little unclear because you use the term oil but this is in a tranny forum. if your changin the tranny fluid then yes drop the pan and change the filter while your at it if its the motor oil no just remove the oil drain plug. dont forget to inspect for metal grit in either just to show wear on internals.
__________________
1994 Ranger Super Cab XLT 4.0L with Eagle rims and 31/10.50/15 Wild Country FW's!! ![]() 1987 Zuki Samurai 1.3L 5spd soon to be a monster... ![]()
Tweet
#4 |
Year: 2006
Make: Ford
Model: F250 FX4
Class: 4x4
Oops, yes this is the tranny forum... Damn the "new Post" impulsive clicking...
It is true, unbolt the pan slowly as this generally makes a big mess.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
