| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Junior Member
Is this the oil pressure sending unit? When the engine is running oil is spewing from there.
![]() When looking from the front of the engine, it is to the right and behind the crank pulley above the i-beams. It has an electrical connection. **edit: Sorry. It is a '90 4.0 2wd Ranger
Tweet
#2 |
Year: 1993
Make: Ford
Model: Ranger XLT
Class: 4X4
Used For: DD, Wheeling,
Rep Power: 0 ![]() iTrader: (0)
yep, i believe thats what it is.
__________________
" MAKG-If you're making a snorkel, you don't need anywhere near 3 inches. You're not going to be running drag races in a river" 93' EXT,on the second 302H.O 3" single exaust,Deltaflow 40/AOD/13-56/F-150 coils, Explorer/ranger leafs. |
Tweet
#3 |
Logan Andrew Feb 17, 2012
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (15)
Yep, pull it out and put a cap in it for now. Standard pipe thread.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop. |
Tweet
#4 |
It's only money...
Year: 1993
Make: Ford
Model: Ranger
Rep Power: 10 ![]() iTrader: (2)
Yup, what everyone else said. The good news is that if it's leaking from the threads, you can just use some thread sealant. The sender is also quite easy to replace, and they're cheap like borscht.
__________________
Blue 93 Ranger 4.0L 4x4 5spd, 38.5's on 16x10's EB coils, 6" Skyjacker Leafs, Belltech 6400's, Bilstein 5150's Fullwidth D60, Lockright, 5.38's, Dedenbear C's 14BFF, 5.38's, Detroit, Disc Braked 3" B/L, Dual batteries, 9500lb winch, Bushwacker cutouts |
Tweet
#5 |
Junior Member
Well I got that fixed. Super easy.
It just made me a little frantic when I am driving and all of a sudden the oil pressure goes to 0 and the oil light comes, and I pull over and oil is dumping out of the underside of my engine. whew... Could have been super ugly. Thanks for the help |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
