Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Brakes
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 10-12-2007, 06:10 PM   #1
Shotokan1509
Shotokan1509's Avatar
Year: 95
Make: Ford
Model: Ranger
Engine: 4.0 V6
Class: 4X4
Shotokan1509 is on a distinguished road
Default 95 ranger front abs sensor, help asap, middle of job
My apologies on cluttering the general board with a specific question but I'm stuck. Got the spindle bolts off, but the abs sensor is in the way. I took the bolt off the back of the electrical connector, how do I get the sensor to slide back? Can I push from the outboard side or will I ruin the sensor? Second, how do I get the block around the sensor off the outside of the spindle? I see a small bolt, but its completely round from rust.
__________________
1995 Ford Ranger ext cab 4.0V6 4x4 auto trans
31x10.5x15 BFG A/T KO's, Warn "Jeep" hubs, leveling coils, Procomp ES9000's
2006 Mustang GT premium
2005 Subaru Legacy GT limited
Shotokan1509 is offline   Reply With Quote
Old 10-12-2007, 06:18 PM   #2
Bill
Bill's Avatar
Year: 2007
Make: Ford
Model: Ranger
Bill is on a distinguished road
Default
It slides out. Sometimes they are a little difficult to get out due to the road grime that "glues" them in there.
__________________
1995 Ranger XLT, 4.0L V6 Automatic
2007 Ranger XLT, 2.3L Duratec, Manual
Bill is offline   Reply With Quote
Old 10-12-2007, 06:19 PM   #3
Shotokan1509
Year: 95
Make: Ford
Model: Ranger
Engine: 4.0 V6
Class: 4X4
Default
Quote:
Do I have to pull from the back, or can I give it some oomph from the front (disc side)? Pretty difficult to get my fingers, let alone a pair of pliers in there from the back with the axle ears in teh way.
EDIT: And does that lower bolt have to be out before the sensor will slide back? or is that just holding that block on the front? It would be easier to work on that round bolt if I can get the sensor out of the way.
__________________
Old 10-12-2007, 07:10 PM   #4
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to behold
Default
There is another bolt that holds on that "Shield" (chunk of metal)
It isn't "round" from rust it's round because it is nearly round it's a 6mm 12point head
and you need a long necked deep socket to get the little bugger off.
Either that or a cheap 6mm deep socket that you don't care about that you can drive on with a hammer and half expect to throw away.
AD
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun.
AllanD is offline   Reply With Quote
Old 10-12-2007, 08:22 PM   #5
Shotokan1509
Year: 95
Make: Ford
Model: Ranger
Engine: 4.0 V6
Class: 4X4
Default
AD
AD
6mm 6point is what I started with and it didn't need a hammer. I guess I'll need to try to find a 6mm bolt out, because I doubt I can get enough room to hammer a 5mm on there. Does that shield need to come off before the sensor will slide out?
__________________
Old 10-22-2007, 02:14 PM   #6
AllanD
Year: 1987... sorta
Make: Ford
Engine: '93 4.0
Class: 4x4
Default
I have never in 30-odd attempts to do so succeded in getting one
of those front wheel ABS sensors out without resorting to "extreme means"
In this case "extreme means" is a really big taper punch and a BFH to drive it with
and the sensor comes out in pieces.
this is why I suggested doing proper diagnosis before disassembling ANYTHING in
the ABS system
the problem is that the front sensor outer shell is stainless steel
and the steering knuckle rusts it into place, ass the knuckle rusts
it swells and the flakey swollen rust locks the tubular body into
the sensor so firmly that the bolt becomes irrelevant.
AD
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
