Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 01-29-2009, 03:24 PM   #1
Lifted2x
Lifted2x's Avatar
Year: 1994
Make: Ford
Model: Explorer
Engine: 4.0
Class: 4x4
Used For: Trails, DD
Lifted2x is on a distinguished road
Default Crank but wont start
Well I got myself involved in another mess of a truck. It is a 90 cab and engine(4.0) with a 86 frame, trans, TC and axles. It looks like the person that did the work did a good job there isnt any splices or bad wiring. But now that its all together there is something that is not working right. It has power where it should and I already checked all the fuses. But it doesnt have any spark. When I connect a test light to pull the codes it is very dim (low voltage) and will not do anything other than shut off when the key is turned on. (it does this with the ecm removed also) I checked for power to the ecm and it has power and I can trigger the fuel pump through the pins. But still nothing I have even replace the ecm from another truck but that didnt work. Any Ideas?
Lifted2x is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
