| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Stock
Rep Power: 12 ![]() iTrader: (1)
Got home after a quick drive, saw some coolant leaking. It's coming from up by the upper heater hose, out of the seam between the radiator fins and the side posts (not sure of a better word?). At any rate, it'll need to be replaced. Used radiators are about $50, new ones are about $140. Is this something you can get by with used, or is it worth going new? I mean, if mine went bad, I can't imagine the used ones would be much better.
Just curious if anyone had any experiences or thoughts. |
Tweet
#2 |
Year: 1992
Make: ford
Model: ranger
Engine: 4.0
Class: 4x4
Used For: street and dirt
Rep Power: 0 ![]() iTrader: (0)
Yeah get a new one,that way you don't have to worry about a used one leaking also, I just replaced mine a week ago it was also leaking at the seams. Don't forget to get new hoses and clamps. Good luck
Tweet
#3 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Yours is "used" too.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes. Build Thread My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime. |
Tweet
#4 |
Year: 1994
Make: Explorer Sport
Engine: 4.0
Class: 2WD
Used For: Work
Rep Power: 15 ![]() iTrader: (0)
You can have that one repaired if you have a local repair shop. They will clean it and replace the cap. I just had my Explorer done, $107 bucks here. Normal cleaning is $67.)shady
Tweet
#5 |
Year: 2001
Make: ford
Model: ranger
Engine: 3.0V6
Class: 2wd offroad
Used For: haul dirt bikes, and play in the mud
Rep Power: 12 ![]() iTrader: (0)
Well if the new one is 140 and you paid 107 to repair a used one it would seem to be a better investment to just buy the new one not have ot worry bout leakage again, just buy the new one locovaca
__________________
2001 Ranger XLT 3.0L 2WD camburg 5.5 f31 deavers 33" maxxis buckshot 1059 pro comp wheels Fox Shox/Premeir Pioneer sound system http://www.cardomain.com/ride/2978855 |
Tweet
#6 |
Year: 1994
Engine: 4.0
Class: 2WD
Used For: Work
I took the radiator in for cleaning. It was discovered that the end cap was cracked. I needed the truck asap. No one stocked a radiator around the corner. I would have to wait a day or longer if I ordered it, or driven in to Houston to pick one up. All this adds to the cost of a new radiator even if I could locate one for $140, plus tax of .0925%. So the cost would have been much more than $140. I have no worries as to the radiator leaking. If it does, I can take it right back to the shop.
shady
Tweet
#7 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
That depends a lot on your area. Our local radiator shop is an hour away and he isn't the quickest at getting things done.
For radiators as cheap as a RBV it is easier/cheaper to just stick in a new one when they get one in.
__________________
Tweet
#8 |
Year: 2001
Make: ford
Model: ranger
Engine: 3.0V6
Class: 2wd offroad
If it breaks again your gunna end up spending more money to again fix it, jb weld that bad boy and order a new one, they are cheap so its not that big of deal, most radiator shops can get them pretty fast
__________________
Tweet
#9 |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Stock
Thanks for the info. I checked around and it turns out Rock Auto has them for about $115, so I'll probably head that route.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
