| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9L
Class: 2WD
Rep Power: 0 ![]() iTrader: (0)
Well first off you just need to know that this 87 ranger has been sitting in my basement for about 8 years, so that is most of the source of my problems. The engine has been rebuilt and i have been driving it for about 4 or 5 days with no problem.
The engine sounds fine, and it rev's fine, but now its having a real hard time accelerating. If you hold the pedal over 1/4 down it will just stall so ive just had to feather the gas to even struggle to get past 45 mph. Also its blowing TONS of smoke out the exaust. I figured there was some place where oil was leaking into the cylinders. I read somewhere online that rangers will sometimes get a hole in the diaphragm of the pressure regulator and was mixing oil with fuel. Replaced the regulator and am still having the problem. I also noticed a oil leak twards the front of the crankshatf. Not sure if its the front gasket or if its dripping from somewhere else. I figgured before i take it to a mechanic and have to empty my wallet I'd make sure im not missing something very simple.I am only 18 years old so i am on a fixed budget so if there is anyone who has any advice i would greatly appriate it. Thanks! |
Tweet
#2 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.9L
Class: 2WD Street
Used For: Inducing terror in passengers
Rep Power: 11 ![]() iTrader: (0)
What color is the smoke coming out of the tailpipe?
Have you checked the oil for milkyness? |
Tweet
#3 |
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9L
Class: 2WD
The smoke is white, it looks like regular exaust. The oil leaking out the bottom looks fine but when i check the stick it is about half way up, and "max" is only the first 2 or 3 inches.
Tweet
#4 |
Year: 2002 1988
Make: honda and ford
Model: CR-v and Bronco
Engine: 2.4l/5.0
Class: 4x4
Used For: dd/toy
Rep Power: 13 ![]() iTrader: (1)
cracked head/blown headgasket
__________________
retired TRS member Currently on Fullsizebronco.com under same name current toy: 88 Bronco 35s stock/ no sway bars 5.0/AOD/BWt-case 210k miles 4.10 gears, Rock sliders, chopped quaters far future mods: D60/10.25 sas/removable doors/custom bumpers |
Tweet
#5 |
Guilty by association
Year: 1993
Make: Ford
Model: Ranger STX X-Cab
Engine: 4.0
Class: 4x4
Used For: Whatever the wife won't let me do in the Jeep.
Rep Power: 15 ![]() ![]() ![]() iTrader: (0)
yep--i concur. (always wanted to say that)
__________________
Only 2 defining forces have ever offered to die for you.....Jesus Christ and the American Soldier. One died for your soul, the other for your freedom. Got a new ranger.... ![]()
Tweet
#8 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
Rep Power: 20 ![]() ![]() ![]() iTrader: (0)
If its halfway up the stick as in 5-6 inches, tehn it is way overfull. That will explain alot of smoke, unless i misunderstood what you were saying. you should drain the oil completely, check the plug and refill with the proper level of oil. Use a lucas oil treatment too.
Tweet
#10 |
Year: 1986
Make: Ford Ranger
Engine: 2.9L
Class: 4X4
Used For: Work and Play
Rep Power: 9 ![]() iTrader: (0)
So how does that stuff work? I've seen it before, but I don't know of anyone who uses it.
__________________
1986 Ford Ranger 2.9L / 4X4 / A4LD "...In a world where most men seem to spend their lives doing things they hate, my fishing is at once an endless source of delight and act of small rebellion." - Robert Traver - Testament of a Fisherman Tattooed people are art collectors that bring their gallery with them. |
Tweet
#11 | |
Year: 1987
Make: Ford
Model: Ranger
Engine: NONE
Class: 2WD
Used For: Working on
Rep Power: 21 ![]() ![]() ![]() ![]() iTrader: (5)
Quote:
Pete |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
