- Oct 8, 2007
Hello, I am currently working one a project that involves wood gasification to run a 94 b2300 pickup. This consists of a device I built called a wood gasifier; which burns wood or other substances in a oxygen deprived environment, than it is subsequently cooled and filtered. This gas can run an engine, with a few changes such as timing and the addition of a mixing valve. For more info check out these links www.allenergies.net en.wikipedia.org/wiki/Wood_gas and http://www.vedbil.se/indexe.shtml
The dilema I’m in right now is not being able to advance the timing, is there a way of doing so without converting back to the 85-88 FI system for the 2.3. If I need to convert what would be required? Could the existing ECM get a trigger signal from just a distributor and module combo, like the old Bosch systems? (I also know I need the older intake) Well I am looking for all you Ford experts out there, as your help and knowledge will be much appreciated.
Thanks, Casey
Thanks, Casey
