rear springs
88BII
15+ Year Member
Florida
1985
is there any other spring that is the same length as the bronco 2 spring? like an f150 0r something like that? doing a sas and need rear springs, some where in the neighbor hood of 6''.
4 door Explorer springs will get you about 2"... with Belltech shackles you can make that 3.5-4". Then you could cut the eyes off the BII main leaf and put in under the Ex main and that would put you close to 5-6".
If you don't want to do that, you could get a set of Skyjackers or swap in a set of Chevy 63s. That involves moving your front spring hangers forward 6" though.
i was thinking about a set of f150 springs, my front springs are 10'' superlift leafs and i need to level the back with springs and a 4'' block
Don't run a 4" block, especially since you're wheeling hard enough to need a D44....
