dana 35 ouch. Any sugestions?
dandeman
15+ Year Member
i got a 90 bronco i think it has a dana 35 it has a manual t-case i dont know if that makes a difference. But i was wondering what would be the best way to fix this. I know replacement what be the best option. Thats what im going to do. i was wondering how much another dana 35 front end would cost me? Anybody have one, that is good that they wanna sell? I want to be able to use the 4 wheel drive its useless having 4 wheel drive and you cant use it. Also need a front driveshaft. When i bought it didnt have on it and i thought it was because of a seal or something. Didnt think it was cause of that!!!:bad:
  • dana 35 ouch. Any sugestions?
replace the pig and try not to high center it on any more rocks. a junkyard would be your best bet for a new diff....and you might as well grab a new driveline while your there. make sure you get a pig with the same gear ratio as you have now.
i bought it like that, i know it dont look good, how much doe u think it will cost me?
depends on the junkyard. your best bet would be just to stop by and ask.
ya true, but they have to have one, most places round here dont have many b2s n the junk yard i would have to go to wichita.
any d35 from any TTB ranger, explorer, or BII will work. you can always call ahead and ask before taking a road trip.
ya true thats what i was going to do. Are the dana 35s n the explorer and ranger exactly the same basically a bolt in sway. Same width etc... Ya the gears would have to be the same ill have to look for that tag on my rear diff
ya beside the gearing factor. Do you know about what range of gears they put in these?
anything from the weak 3.27's to the rare 4.10's. there is a 3.08 ratio available too, but i dont think those went into 4x4's...at least ive never seen any.
aw ok well when i replace it i prolly should install a 4" lift while im at it, it would be worth all the work.
a lift is a lot of extra work. you dont need to pull the pig to install a lift...so you arent saving yourself any work.
i know but since i already have to replace it might as well install the lift while im under there. i was thinkin bout a dana 44 swap but this is my daily beater and i dont need a trail rig just one im not gonna get stuck in on a daily basis
a d44 really isnt worth it IMO. the d35 is a plenty strong unit and with a few simple mods can be made even stronger.
the part you are calling the pig the diff is the third member right?
