| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Mini-Truck Suspension All you lowriders step inside and post up. Forum sponsored by Illusive Design & Fabrication |
Thread Tools | Display Modes |
#1 |
Year: 1989/1992
Make: Fo Mo Co
Model: Ranger Ex-cab/Explorer Sport
Engine: 2.9L....for now/4.0L
Class: 4x4
Used For: Truck Type Needs/DD Mileage
Rep Power: 0 ![]() iTrader: (5)
what all is involved in doing something like this? I plan to do this on the 92 explorer in my sig. I know I need the beams, steering, spindles and brakes but what else? I know its obvious I need a 2wd tranny but is it possible or cheaper to convert the tailshaft to 2wd or will the entire tranny need to be replaced? to my knowledge the I beam brackets look to be in the same place on either frame (2wd/4wd) same with the crossmember. any input will be appreciated.
Tweet
#2 |
I dance with the Devil...
Sell your Explorer and find a 2wd one. They are a dime a dozen.
__________________
I shall not surrender... I shall not retreat... I will stand here and fight... Or I will stand here and die! All men are created equal, then a few become firemen. Support Our Troops! |
Tweet
#3 | ||
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Rep Power: 25 ![]() iTrader: (0)
the front engine/suspension crossmember is different between 2wd and 4wd. you'll have to grind all the rivets out of yours and a donor 2wd and bolt the 2wd crossmember into your truck (not fun).
the mainshaft is different between 2wd and 4wd transmissions...and to replace that requires the entire transmission to be disassembled. your best bet would be to swap in a 2wd trans. but...why not just lower the 4wd and make it AWD?
__________________
As seen on the internets! Quote:
Quote:
Tweet
#5 | ||
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
you can. but my point was its not worth it.
plus you would both still need to find appropriate transmissions since yours arent compatible.
__________________
Quote:
Tweet
#6 | |
Year: 1989/1992
Make: Fo Mo Co
Class: 4x4
Quote:
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
