Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Non-Ranger Axles
Notices
Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc.
Post New Thread Reply
Thread Tools Display Modes
Old 01-09-2009, 04:32 PM   #1
Gum-B
Junior Member
Gum-B's Avatar
Year: 1994
Make: Ford
Model: Ranger XL
Engine: 2.3L
Class: 4x4
Used For: everything my R1 cant do
Gum-B is on a distinguished road
Default Full Width D44 v. Shortened D44
Ok i have decided that the D35 must go. I need beter gearing and 4.88 will not cut it. I use my truck mostly off road, it does see pavement but not much, and i have never needed to go over 60. It is not my daily driver so it must be modified. I am curious if it is best to go with a Full width D44 , or to go with a narrowed one. If i go full width is it best to go with a full width rear or can i stay with the short rear axle. I am leaning more towards leaf springs up front rather than try to do the radius arms. and i want some mean gears like 5.13 or numeracially higher. I only want a 33 to 35 inch tire, but i want a much lower gear ratio. The D44 is the axle i think i need, my real question is swap both for full width, swap the front for full width, or swap in a short width axle. If there is a beter axle that i should look for let me know i have a full width D44 that i can pull, and a 14-Bolt that i can pull as well. Any input would be awesome.
__________________
Store Manager
Audio Concepts, Pullman
-Installers do it in Your car!!
Gum-B is offline   Reply With Quote
Old 01-09-2009, 04:48 PM   #2
1badexplorer
1badexplorer's Avatar
Year: 97,79,00,72,71
Make: Ford
Model: Ranger, F250, F350, Mustang, Bronco
Engine: 3.0, 460, 7.3psd, 351c, 351w
Class: little bit of everything
Used For: waste all my money
1badexplorer is on a distinguished road
Default
I would deff go full width, it helps with stability, and you can use stock axle shafts instead of buying new after market ones. If you want a leaf spring 44 its gotta be coming out of a f250 or a f150 thats a extended cab. If you run the 14bolt (which is what i've just switched my trail truck to) You will have 8 bolt wheels which is nice because you have bigger brakes then. Find a 44 out of a 77.5-79 f250 because its high pinion, and disk brakes, already and they are cheap. I got a few if you can't locate one near you.
__________________
97 Ranger 3.0 5spd 1354m disc 8.8
00 F350 Dually Crewcab 4x4 7.3 6spd
79 F250 501BBF,4spd, d60, 10.25 38s
72 Mustang Mach1 351C, 4spd
71 Bronco d60, 14bt, 351efi, 4spd,203/205, 44s beadlocks plus lots more
1badexplorer is offline   Reply With Quote
Old 01-09-2009, 07:14 PM   #3
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
Not a huge difference between 4.88 and 5.13, although it does suck that we've now been left out in the cold here with the hustlings in management at Precision Gear
If the opportunity is there though, and this is mainly a wheeling toy, I would definitely go full width (I regret it a bit not doing this when I put the D44 in my Ranger). I would run a full width rear just so it doesn't look so funny. I don't see it having too dramatic of an effect on handling though.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 01-09-2009, 08:44 PM   #4
np205
np205's Avatar
Year: 95
Make: Ford
Model: F250
Engine: 7.3
Class: 4X4
Used For: Work and play
np205 is a jewel in the roughnp205 is a jewel in the roughnp205 is a jewel in the roughnp205 is a jewel in the rough
Default
If you want to get rid of the 4.88's let me know ;), I'll take them off your hands.
__________________
95 F250 Xtracab Powerstroke, 5 speed, 4X4, Stock for now
np205 is offline   Reply With Quote
Old 01-09-2009, 09:16 PM   #5
AKBroncoII
AKBroncoII is on a distinguished road
Default
out could always use wagoneer stuff. It's wider than eb stuff. I've owned both and like both. Not having a good set of fender flares for my b2 made me settle with narrow stuff.
AKBroncoII is offline   Reply With Quote
Old 01-09-2009, 10:30 PM   #6
wahlstrom1
J-man HD Mech
wahlstrom1's Avatar
wahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the rough
Default
Only downside to running fullwidths is I find myself too wide even at EB (stock) width on some trails and I have to find new line's when the old yota's are just plowing through it without a scratch.
-andrew
__________________
UNDER RE-CONSTRUCTION
97' U.A. Ranger, Bent and Broke...
Quote:
Originally Posted by Kyle M. View Post
LOL, wheres the loony bin, cuz we be crazay
wahlstrom1 is offline   Reply With Quote
Old 01-10-2009, 08:46 PM   #7
Bent Bolt
Bent Bolt's Avatar
Year: 1987
Make: Ford
Model: Ranger STX
Engine: Supercharged 4.0 SOHC
Class: 4x4 Offroad
Used For: Breaking parts , sitting in the back lot
Bent Bolt is on a distinguished road
Default
Quote:
-andrew
LOL !! You must be wheeling around Rocky Mountain House !! That's exactly my thoughts on this subject. I've been in plenty of places where a full width axle simply would not fit.
__________________
87 Ranger , a bunch of stuff including a supercharged 4.0l SOHC and 35 x 14.5 x 15 Pitbull Maddog's. Woof !
Now with C5/C4 hybrid !
Bent Bolt is offline   Reply With Quote
Old 01-10-2009, 09:09 PM   #8
wahlstrom1
J-man HD Mech
wahlstrom1's Avatar
Default
Yup, lot's of trails out west but still an hr's drive from Red Deer by the time you actually get to the trail......
-andrew
__________________
Old 01-12-2009, 12:26 AM   #9
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Engine: 2.9L, 4.0L
Default
I would've easily thought that about the Dusy / Ershim trail out here in the Sierra Mtns. (even betting $$$ on it), but this dude I was with on fullwidth axles and 38x14.5" TSL SXs on a YJ successfully squeezed that thing right on past all the trees and rocks through the whole trail without too much issue. I was definitely surprised to see him do it.
__________________
'90 Bronco II XLT
'94 Ranger XLT
Old 01-12-2009, 12:51 AM   #10
86ford
86ford's Avatar
Year: 1992
Make: FORD
Model: Exploder
Engine: 4.0, abused and misunderstood
Class: 4x4 locked
Used For: creating a need for a larger broken parts bin
86ford is on a distinguished road
Send a message via AIM to 86ford
Default
the weight increase that you will be adding with a 14bolt FF and a d44 will nearly off set your gain in gearing. by the time you get the 2 axles built and swapped you could of nearly purchased a Atlas t-case and have even better gearing with one tenth the headache...
86
86ford is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
