Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2001 & Newer)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 01-01-2009, 04:37 PM   #1
BCWW
BCWW's Avatar
Year: 2005
Make: Ford
Model: Ranger
Engine: 2.3 liter
Class: 2WD
Used For: Work
BCWW is on a distinguished road
Default PCV Valve Location
Sorry for the dumb question, but where is the PCV valve located on my 2005 2.3l. I have look in the obvious places and the not so obvious and am at my wits end.
Thanks
Bryan
BCWW is offline   Reply With Quote
Old 01-01-2009, 08:24 PM   #2
trioxin1308
Year: 03
Make: Ford
Model: Ranger
trioxin1308 is on a distinguished road
Default PCV location
Brian,
This drove me nuts too. You'll find it on the bottom half of the right side of the engine as you stand in front of the truck facing it. It helps to remove the soft rubber splash guard inside the tire well. Getting at it from inside the fenderwell was the easiest for me, and I found taking the tire off was the best way about it. If you follow the hose from the back of the intake going down, you'll find it.
T.
trioxin1308 is offline   Reply With Quote
Old 01-08-2009, 11:51 PM   #3
jax4bangin
jax4bangin's Avatar
Year: 2007
Make: ford
Model: ranger
Engine: 2.3
Class: 2WD
Used For: haulin my d bike around
jax4bangin is on a distinguished road
Default
what is the purpose of the PCV? what job does it do?
jax4bangin is offline   Reply With Quote
Old 01-14-2009, 02:20 PM   #4
dorman68
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
dorman68 is on a distinguished road
Default
The pcv valve is on the side of the engine with the intake manifold. You have to look real hard behind the intake manifold, the pcv valve sits in crankcase vent oil separator box on the side of the engine block. Here are intructions from Alldata, not to clear but hope it helps.
POSITIVE CRANKCASE VENTILATION (PCV) VALVE
Removal and Installation
Remove the left front inner fenderwell splash shield.
Disconnect the coolant bypass hose from the routing clip.
Gently pry the positive crankcase ventilation (PCV) valve cap off the two tabs.
Remove the PCV valve from the crankcase vent oil separator and disconnect the vacuum hose.
To install, reverse the removal procedure.
__________________
1993 Ranger 2.3L,5-spd-2wd - 149,000 mi.(slow as dog-dirt)
1994 Ranger 2.3L,Auto-2wd - 155,000 mi.(Sold)
2005 Corolla LE - AT Trans
dorman68 is offline   Reply With Quote
Old 01-14-2009, 02:56 PM   #5
Wicked_Sludge
Wicked_Sludge's Avatar
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Wicked_Sludge will become famous soon enough
Send a message via MSN to Wicked_Sludge
Default
PCV stands for Positive Crankcase Ventalation. as the name implies, it forcefully ventilates the crank case using the engines vacuum to pull air through the crankcase, thus preventing the buildup of fumes (even healthy engines have a minimal amount of blowby) inside the crankcase. its good for your oil, its good for your fuel economy, and its good for the environment.
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 01-16-2009, 09:44 AM   #6
BCWW
BCWW's Avatar
Year: 2005
Make: Ford
Model: Ranger
Engine: 2.3 liter
Class: 2WD
Used For: Work
Default
I finally found it and got it changed. What a screwed up location. Thanks for the help.
Bryan
Old 02-16-2010, 08:51 PM   #7
nederanger
Year: 2005
Make: Ford
Model: Ranger XL
Engine: 2.3 L
Class: 2WD
Used For: traction-free 4wd-ing
nederanger is on a distinguished road
Default PCV valve cap removal
Quote:
I've got the splash guard and wheel off and have located the PCV valve, but now I'm stuck. I see 1 horizontal slit about 1/4 inch long on each side of the cap and I can rotate the cap a little, but how do you pry the cap off? With a screwdriver? and what to pry against?
A little help please.
nederanger is offline   Reply With Quote
Old 02-16-2010, 08:59 PM   #8
88_Eddie
Motorboater (.Y.)
Chopper Challenge Champion
88_Eddie's Avatar
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
Quote:
Bryan
it's in a bad spot in my 4.0L SOHC too, the BACK of the block, cant even hardly get to it.
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
