| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1990
Make: Ford
Model: Ranger STX
Engine: 2.9
Class: 4x4
Used For: DD and weekend offroader
Rep Power: 11 ![]() iTrader: (0)
alright im buying a 87 ford ranger and im doing a v8 swap but not sure if i wanta do EFI or carbarated im leaning more toward the cabarated but not sure what car to get it out of any suggestions anything will help im 15 so this will be fun
Tweet
#3 |
Year: 1988
Make: Ford
Model: Ranger Supercab
Engine: 2.3L Turbo
Class: 2WD
Used For: Nothing yet. Still a work in progress.
Rep Power: 10 ![]() iTrader: (0)
The V8 forum and search function are your friend.
__________________
Tweet
#4 |
Year: 1990
Make: Ford
Model: Ranger STX
Engine: 2.9
Class: 4x4
i was looking to do carb because with EFI i gotta get the computer and stuff from the car
Tweet
#5 |
Year: 1988
Make: Ford
Model: Ranger Super Cab
Engine: 2.9
Class: 4x4 Work
Used For: 4 Wheeling and Hauling Firewood.
Rep Power: 12 ![]() iTrader: (1)
yeah but after its all said and done you wont have retune that carb every fall and spring.
Tweet
#8 |
Year: 1988
Make: Ford
Engine: 2.9
Class: 4x4 Work
On the bright side carb is easier. But just think what people are going to say when you pop the hood and they see EFI, and it looks like a stock 302 ranger. Take your time and do a clean job and it will look good. Oh and TAKE PICS!
Tweet
#9 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
Rep Power: 20 ![]() ![]() ![]() iTrader: (0)
For a ranger swap it will never be simpler or cheaper than carb. I personally am a fan of EFI for the mileage and absolute power that can be tuned. But for a ranger? definitely carb, you'll have enough issues with even a smooth install that using EFI wont be worth the effort.
Tweet
#10 |
Year: 85
Make: ford
Model: ranger
Engine: 302
Class: 4x4
Used For: Yard Decoration
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
__________________
Stabbings aren't funny Beatings aren't funny Clowns aren't funny But Beating and Stabbing a Clown...Thats Funny! |
Tweet
#11 |
Year: 1993
Make: ford
Model: ranger
Engine: 347 stroker
Class: 2wd Off-Road
Used For: play
Rep Power: 0 ![]() iTrader: (0)
the tech library is a great area for info, i helped my buddy swap one in his and am currently putting one in my 93. take your time and do it right. just make sure you save all your recipts in case you get parts that don't fit, or can't be modified to fit. a body lift is a great time saver for fitting both the motor and tranny. if you plan on 4x4 it is a lot easier to separate the tranny and t-case before install. also don't be afraid to cut some pieces out of your frame rails, it sucks but is neccesary. good luck bud!
__________________
93 Ranger 2wd Std Cab Long Bed 6" Skyjacker suspension 2" Coil Spacers 3" Body Lift 35" KM's Custom Front Tube Bumper Soon to come...347 stroker(installed), NP435(installed), NP205, Dana 35(scratch that,44), and Ford 8.8...That's Right V-8 and 4wd |
Tweet
#12 |
Year: 1987
Make: Ford
Model: Ranger
Engine: NONE
Class: 2WD
Used For: Working on
Rep Power: 21 ![]() ![]() ![]() ![]() iTrader: (5)
IMO, If you have the motor, but not the electronics, do a carb first to get it going, then switch over EFI when you have the dough to do it right (and sell or hang on to the carb for future projects). A carb intake is cheap, ignition systems are simplistic and cheap. Just be ready to hook up EGR, run cats, and do everything you can to make it "street legal" so you won't have to worry about it later. You can also run a carb with an AOD (NOT E) with the kick down cable and bracket from Lokar (about $80-$100 shipped from Summit). The only down fall is getting the cable set correctly, I am having my truck towed to a transmission shop as I don't have the pressure gauge to do it myself once installed. I've been debating on buying one though..
Pete |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
