Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 12-30-2008, 06:47 PM   #1
BigMikeOn33s
BigMikeOn33s's Avatar
Year: 1993
Make: Ford
Model: Explorer
BigMikeOn33s is on a distinguished road
Default A4LD Trans Help
Hello just joined up here.
Anyhow my trans was acting up like it took 15 sec to shift into first.Then the RPMs would run really high and rev hard and then slam into gear.Well i thought i would change the filter and fluid and see if there was anything there in the pan that might be wrong too.
Well after dropping the pan i found the overdrive anchor pin in the pan.
Now i have to "manually" shift into first.
My question is does anyone know how this pin goes back in?
This has been about a month now and its driving me crazy the way i have to get into first.
Also are there any long term problems that might occur if this doesnt get fixed?
Thanks for any help.
Mike
BigMikeOn33s is offline   Reply With Quote
Old 12-31-2008, 11:08 AM   #2
fordmandan87
fordmandan87's Avatar
Year: 86/87/92/03
Make: Ford/Ford/Ford/
Model: F-250/Crown Vic/Explorer/T-600
Engine: 5.0/5.0/4.0/C15 CAT!!!!
Class: 4x2/4x2/4x4/6x4
Used For: Everything it was not designed to do/DD
fordmandan87 is a jewel in the roughfordmandan87 is a jewel in the roughfordmandan87 is a jewel in the roughfordmandan87 is a jewel in the rough
Default
TOTAL TRANNY FAILURE get another one those things SUCK BALLS
fordmandan87 is offline   Reply With Quote
Old 12-31-2008, 02:57 PM   #3
Explorin94
Explorin94's Avatar
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Trail Slut
Explorin94 is just really niceExplorin94 is just really niceExplorin94 is just really niceExplorin94 is just really nice
Default
I seen your question on MYMUDSPACE too. You have serious internal transmission problems, that pin shouldn't fall out. Take it to a transmission shop or pull it and then take it to one to have it rebuilt. An A4LD can be built to withstand 600-700 horse with the right internal components.
__________________
HE WHO DIES WITH THE MOST TOYS WINS
Explorin94 is offline   Reply With Quote
Old 12-31-2008, 05:18 PM   #4
BigMikeOn33s
Year: 1993
Make: Ford
Model: Explorer
Default
Quote:
Yes it was there also.
i was looking for any place to find help at really.
But thanks for the response.Rebuild is looking like what ill have to do.
Old 12-31-2008, 06:17 PM   #5
jaymegriffiths
jaymegriffiths's Avatar
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9
Class: 2wd street,4x4 currently Front-WD
Used For: screaming at
jaymegriffiths is on a distinguished road
Default
Try checking wreckers first, it's often cheaper than a rebuild. plus for like 100 bucks they will pull it.(way faster)
__________________
Quote:
Originally Posted by Frank The Tank View Post
if you guys really hate buying it so much, get a bigger tank and stop resetting the trip mileage and just drive.
Quote:
Originally Posted by baddad457 View Post
And that's a 600 cfm Holley and you've got it mounted backwards
88 2wd 2.9
jaymegriffiths is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
