Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 12-30-2008, 04:10 AM   #1
rranger
Year: 1985
Make: Ford
Model: Ranger
Engine: V6 2.8 2bbl
Class: 2WD
Used For: Fixing
rranger is on a distinguished road
Default Torque converter clutch solenoid
Were on the 1985 ranger auto trans 4spd is the t/c clutch plate solenoid?
I heard on some cars its in the trans.
I want to test the solenoid, & it has to be removed to test.
Here is the tech. article on the part Im looking to find on my ranger:
The hydraulic lockup that occurs is not the same as the mechanical lockup that occurs in a torque converter equipped with a computer-controlled mechanical clutch. Because there is no mechanical connection between the impeller and turbine wheels, an ordinary torque converter will experience up to 10 percent slippage between the engine and transmission. This hurts fuel economy and performance, so the torque converters in most late-model vehicles have a computer-controlled pressure plate that locks up against the housing when the vehicle is about a certain speed and/or is in higher gears. A "computer-controlled solenoid" controls the flow of hydraulic pressure from the transmission to apply and release the pressure plate. When the plate is engaged, there is no slippage between the engine and transmission, and the torque converter acts like a solid member in the driveline. But when the brakes are applied or the vehicle is idling with the transmission in gear, the pressure plate is released so the torque converter can slip.
rranger is offline   Reply With Quote
Old 12-30-2008, 07:24 PM   #2
rranger
Year: 1985
Make: Ford
Model: Ranger
Engine: V6 2.8 2bbl
Class: 2WD
Used For: Fixing
Default
Im pretty shure its located on the valve body, under the trans. pan.
The t/c solenoid is on the other side of the valve body, its like a shift solenoid. Im trying to get some one's insight that has worked on ranger transmissions. My problem is that the car immidiatley dies when its shifted into any gear. First i thought its the t/c total failer, but I read the the t/c's solenoid controls the lock up, so now i want to test the solenoid but I know nothing about it really.
computer controled "t/c solenoid" lock-up
Q's:
1.correct Location?
2.correct ohm range?
Old 12-30-2008, 07:41 PM   #3
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Yes you have to pull the pan to remove the solenoid, there will be a connector on the side of the transmission, you should be able to test it there.
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is online now   Reply With Quote
Old 12-30-2008, 07:46 PM   #4
igiveup
igiveup is on a distinguished road
Default
Hello
Your transmission is A4LD. Your TCC lockup is on the drivers side above the and a couple of inches in front of you shift linkage. Pain in the ass to unplug and a bigger pain in the ass to plug in. At least mine was. Its on the side of your valve body. I have been told by another member from another ford site it should be 25-40 ohms.
I hope this helps.
igiveup
__________________
2011 FX4 Ranger http://therangerstation.com/forums/s...98#post1067998
85 Honda trike 250 SX
2006 F150 4X4 quad door (tow rig)
igiveup is offline   Reply With Quote
Old 01-02-2009, 03:04 AM   #5
rranger
Year: 1985
Make: Ford
Model: Ranger
Engine: V6 2.8 2bbl
Class: 2WD
Used For: Fixing
Default
You guy's are super freakin cool, I have had a hard time getting any information on the rangers a4ld tranmissions solenoid for t/cc lock up. The ohm range you gave allows me to test it, and thats cool, do you know wich plug it is there is a two prong, and there is a 4 prong plug? One plug is round and one is square, can i test the ohm range at the plug? Do I have to have the vehicle running to do the ohm range test on the solenoid?
Is there a way to test the brake switch that activates the t/cc lock up?
I replaced the torque converter last night, and it still dies when put into gear, as im pulling my hair out in flustration, a transmission shop owner tells me the solenoid or brake switch almost allways "go out" when the t/c does with my trucks symptoms, so i will test it I guess?
Old 01-02-2009, 03:27 AM   #6
rranger
Year: 1985
Make: Ford
Model: Ranger
Engine: V6 2.8 2bbl
Class: 2WD
Used For: Fixing
Default
I did the t/c, so now the only thing that can still be locking it up is the tcc's plate. Its activated by the brake pedal to turn on and off, so either the brake switch is faulty , the wiring, or the solenoid itself. I was told its most likley the solenoid, and that they go bad befor the torque converter does, is this true for the ford ranger from 1985???
Dam Electronics!
Old 01-03-2009, 03:18 AM   #7
rranger
Year: 1985
Make: Ford
Model: Ranger
Engine: V6 2.8 2bbl
Class: 2WD
Used For: Fixing
Default
So I replaced the tcc solenoid and now the truck goes into gear just fine, but now it has a huge hesitation before it goes into gear any thoughts on why it would hesitate before going into gear???
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
