| Home | Resources | Tech Library | Magazine | Video Gallery | Truck Gallery | Shirts & Decals | Parts |
| Register | FAQ | Members List | Calendar | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
Year: 1995 Ranger
Make: EXT Cab Splash
Model: 6" Lift 3" Body n 38" TSL's
Engine: Crap.. Not Enought.. 3.0 (WANT A 3.3 Stroker M90 Blower)
Class: Daily Driver--- Playing--- Off Road Recorvery!!!--- Car Shows
Used For: Intimidating (Crushing) Imports....
![]() iTrader: (0)
I just saw this Ranger that Sounds Great..
I want to know what Size/Name/Grind # this cam is... Also Does anyone know who it is??? In May of 2006 he had a Whipple-Charger... http://videos.streetfire.net/video/F...ith_101556.htm At Idle it sounds like a V8.. ME LIKE........!!! Thanx, Rob Lil Ranger
__________________
1995 Ranger EXT Cab Splash.. SkyJacker 6" System Rollin on 38"x15.5" TSL RADIALS.. Tan Heated Leather Eddie Bauer Seats 3" Body Lift n WAY TOO MUCH BASS Last edited by Lil Ranger : 12-24-2008 at 09:54 PM. Reason: Vid Clip |
#2 |
Year: 91
Make: exploder
Model: turbo sport 4x4
Engine: 4.0ohv
Used For: daily driver
![]() iTrader: (0)
that kind of cam would kill the torque ofa 3.0 better have the rigth gearing/stall to make up the torque loss and a nice blower. it would be ok for a play truck but would kill your fuel economy on a DD. If you do alot of stop and go traffic with a big cammed motor alot of fuel is wasted out the pipe(s)
__________________
91 exploder turbo sport 4x4 155rwhp/250rwtrq@5psi now twin compounded turbo Home Brewd Turbo~specializing in custom turbocharging and turbo related parts www.myspace.com/homebrewdturbo |
#3 | ||
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
![]() iTrader: (0)
mine sounds similar if i unplug the IAC (quieter due to stock manifolds).
agreed, the street drivability of that truck would suck. i like the way this one sounds: http://www.youtube.com/watch?v=RQXyCom7X2o more (listen to that thing under load...it sounds rutheless!): http://www.youtube.com/watch?v=d52PiH_oI-U
__________________
As seen on the internets! Quote:
Quote:
Last edited by Wicked_Sludge : Today at 09:16 PM. Last edited by Wicked_Sludge : 12-24-2008 at 10:54 PM. |
#4 | |
Year: 1995 Ranger
![]() iTrader: (0)
Quote:
I have been lookin into V8 Swaps, for a lil more Power but mainly for a Nice Sounding Exhaust... I am now lookin into a M90 SuperCoupe Blower on a 3.0.. Only if I could find a Set of 3.0 Headers with out payin $250 just for better sound.. I finger that Cam + A Blower I would be more then happy.. n still get Good/Decent MPG..
__________________
1995 Ranger EXT Cab Splash.. SkyJacker 6" System Rollin on 38"x15.5" TSL RADIALS.. Tan Heated Leather Eddie Bauer Seats 3" Body Lift n WAY TOO MUCH BASS |
#5 | ||
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
![]() iTrader: (0)
i dont know who it is...but i know the car is popular in the probe crowd.
as turbo cat already said, a cam that will make your truck sound like that is going to lower fuel economy and make the truck not very fun on the street. you dont need to know the exact specs to get a lumpy cam like that, just take it in and have it reground. tell the machinist what you want and he'll make it happen.
__________________
Quote:
#6 |
Year: 91
Make: exploder
Engine: 4.0ohv
![]() iTrader: (0)
headers arent going to make the motor louder. You will gain a small fraction of power but I would go for the big gains then dig into the small bolt ons. If you actually want power go with forced induction. A rough idling cam is becasue it has long duration and a close LSA (more overlap) Most engines with a smooth idling cam for good vaccum is 114-117 area depending on the motor. Alot of big cams range from 108-112 which will give you way more overlap. Lots of overlap and duration (how long the valve is open) allows the motor to intake more air at higher rpms. When a motor is turning 6000 it has a smaller window of time to inhale then it does at 2000. At idle you will have low vaccum due to the big duration and overlap. The low vaccum and overlap will cause the motor to idle rough (the lopey sound you hear) and fuel mixture to blow-by (as in ou tthe exhaust before the exhaust valve closes. Also the issue with big camms is low vaccum to operate vaccum related accesories like your brake booster. Emissions, economy and low rpm torque will be lost to gain power in the upper powerband where most street motors dont need. I wouldnt do it just for sound even a V8 woulnt sound lumpy unless it has a big camm. A big camm liek that you will also need ecu retuning and if you have to pass emissions you will fail. Upgrraded valve springs will also be necesary with big camms.
__________________
91 exploder turbo sport 4x4 155rwhp/250rwtrq@5psi now twin compounded turbo Home Brewd Turbo~specializing in custom turbocharging and turbo related parts www.myspace.com/homebrewdturbo Last edited by turbo cat : 12-25-2008 at 12:32 AM. |
#7 | |
Year: 1995 Ranger
![]() iTrader: (0)
Quote:
Vac Lose wont be a problem, if I do the Cam the M90 Blower will be at/close to the same time..
__________________
#8 | |
Premium Member
![]() ![]() Join Date: Aug 2007
Year: 1988
Make: Ford
Model: Ranger
Engine: 5.0L
Class: 2WD
Used For: Beating on
![]() iTrader: (2)
Quote:
FWIW, Headers on a boosted motor is more than just about sound. That applies to N/A where the exhaust is likely not to be the bottle neck, that's why not much gain. And $250 is nothing compared to what you're talking about building practically.. Pete Edit: I agree with turbocat on vacuum loss as well. My 327 with an exotic cam like that had no power brakes at idle, crappy for a street motor. My V8 going into my Ranger is much milder, will be a hoot on the street. |
#9 | ||
Year: 1993
Make: Ford
Engine: 3-point-GO
Class: 4x4
![]() iTrader: (0)
actually, headers on a supercharged motor can hurt performance. free-flowing headers act to reduce the effective boost the blower can produce. higher boost levels are usually more than enough to compensate for restrictive manifolds.
__________________
Quote:
#10 | |
Year: 91
Make: exploder
Engine: 4.0ohv
![]() iTrader: (0)
Quote:
I built a cat back exhaust for my bros 3.0 and it sounded pretty close to that at idle anyways. All i used was a junked honda resonator and a side exit tip.
__________________
#11 | |
Year: 1995 Ranger
![]() iTrader: (0)
Quote:
When I Said $250 I ment for a set of headers... May gain 5hp, if that.. Better Flowing Exhaust.. I know about Big Cams, Headers, n Blowers.. I have a 331 Stroked N ProCharged Mustang... A smoother Exhaust flow is always better.. Im not saying I want a .450 Lift Cam.. Just that Old School Aggressive Sound.. I have a Mustang with a Turbo Coupe Engine in it for my MPG Car... I want a Nice Sounding Ranger...
__________________
#12 |
Year: 91
Make: exploder
Engine: 4.0ohv
![]() iTrader: (0)
if you want a good sound go for an aftermarket exhaust. But if you slide a bumpstick in to give you that "lumpy idle soud" you will lose in many areas for a DD. Especially a a lifted truck with big tires and a small V6 motor. you need torque not high range power. Daily driving a big cammed car or truck isnt all fun and games. I drove a 4.6L v8 around for years with stage 2 camms. It really guzzles the gas up while cruising/idling thru traffic. When you get out on the highway then everything was good.
__________________
#13 |
Year: 91
Make: exploder
Engine: 4.0ohv
![]() iTrader: (0)
A high lift camm is fine if the valve train is up to the task. A camm with lots of lift dosent create a lumpy idle. A cam with lots of Duration and a close Lobe Seperation Angle does.
__________________
91 exploder turbo sport 4x4 155rwhp/250rwtrq@5psi now twin compounded turbo Home Brewd Turbo~specializing in custom turbocharging and turbo related parts www.myspace.com/homebrewdturbo Last edited by turbo cat : 12-25-2008 at 02:49 AM. |
#14 |
3.0 supporter
![]() Join Date: Jan 2008
Year: 2007
Make: Ford
Model: Ranger
Engine: 3.0 V6 God's gift to man
Class: 2WD Off-Road
Used For: beating the hell out of and abusing lol
![]() iTrader: (0)
if you want a nice sound i suggest you stay away from magnaflow, i had one on my ranger the single in dual out and it sounded like a 4 cyl, i put a Supper 44 Flowmaster on it and at idle it sounds like a V8 as soon as i can get a vid clip i will post it for ya so you can get an idea of how amazing flowmasters sound, IMHO i also think that glass packs sound like complete crap on 3.0 ranger (no offense to anyone) if you want a nice deep low sound go with Flowmaster Super 44 (not super 40) its a great sounding muffler. and its loud
Edit. The flowmaster exhaust with just a pipe extension fits right onto the MagnaFlow pipes that are custom fit for rangers |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
