| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 91
Make: ford
Model: 4.0 ex. cab ranger
Rep Power: 0 ![]() iTrader: (0)
ive got 10 hrs in polishing these wheels...im gonna strap em on my 91 ext. cab 4.0
http://s49.photobucket.com/albums/f2...ent=stk112.jpg http://s49.photobucket.com/albums/f2...ent=stk113.jpg the front are 14x7 and the rear are 14x8.5.... i want 9+ inches of tread on the ground with a 25-27 inch height...the only way i could do this would to go with a bias-ply tire....what would be the down side of this compared to a radial the biggest radial i could find was a 245/60/14 bfgoodrich mesured 25.6 high and tread at 8.6 inches... i have a set of 275/60/14s and thas about the size i want...but these are dry rotted very bad...they are right at 26 high and 9.5 wide...this is the size i want... re fresh my memory....why not a good idea to run the bias-ply tires over radials on a daily driver?
__________________
http://adaptitusa.com/referencebook.htm wheel bolt pattern list http://www.izook.com/gearcalc.htm gear ratio calculator |
Tweet
#2 |
Clean And Articulate
Year: 2008
Make: Ford
Model: Sport Trac
Engine: 4.0
Class: 4x4
Used For: Daily Driver
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
There simply isn't much selection in 14" tires any more. The BFG might be the biggest you'll find unless Mickey Thompson still makes some.
Radials just handle and track better.
__________________
Steeler Nation does not have to travel. We're already there. "It is not the multitude of ale houses that occasions a general disposition toward drunkenness among the common people; but rather disposition arising from other causes necessarily gives employment to a multitude of ale houses." -- Adam Smith, 1776 |
Tweet
#3 |
Year: 91
Make: ford
mickey does make some....they are like semi drag slicks or indy profile tire that are175-200 apeice and all bias-ply
__________________
Tweet
#4 |
Year: 2010
Make: Ford
Model: Ranger FX4
Engine: 4.0
Class: 4x4
Used For: A bit of everything...
Rep Power: 12 ![]() iTrader: (0)
bias ply vs. radial is mostly about heat retention and a bias will create more heat at higher speeds which could cause tire failure...
Stay away from bias on street vehicles, period.
__________________
2010 FX4 4X4, 4.0 SOHC, Auto, Magellan nav, 265/75 16 Toyo Open Country M/T's, 2" TT , 2" Shackles |
Tweet
#5 |
Year: 91
Make: ford
i knew they ran hotter im lookin for 65-70 mph and slower when towing a samurai (2400 lbs) with a tow bar...i want the wider tires for looks and also my foot gets a little heavy and the 4.0 will light em up...
__________________
Tweet
#6 |
Year: 2010
Make: Ford
Model: Ranger FX4
Engine: 4.0
Class: 4x4
I wouldn't recommend em for you. I would ONLY use bias ply on a trail rig that never sees more than 30mph or so....
__________________
Tweet
#7 |
Year: 91
Make: ford
yeah ill have to stick with 245/60/14
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
