Cheap Spring Spacers for Ranger Front Suspension
Z3CHYD
15+ Year Member
U.S. Military - Active
Lancaster, PA
2.3 (4 Cylinder)
Total Drop
3 front 5 rear
225/60R15
When I had 31's on my Ranger the front tires would rub when i would brake hard or go offroading. So I came up with a simple cheap lift i could do with a little engineering and about 5 bucks :) I went to a local sports store and bought 2 hockey pucks for about 2 bucks each. I took them home and drilled holes in the middle for the threading to poke through. 1.5 inches of lift easy.
Firs picture is the spring coming out with a cheater bar, you might need someone else's help to hold the bar while you remove the spring.
[/IMG]
Now with the spring out, you can see that you don't really have that much flex stock (i replaced the shocks to haha)
[/IMG]
Now, if you have some, put some large washers on first, then the hockey puck spacer, and the cupped washer that was originally on the shock. Set the spring on the spacer, and thread the bolt back on.
[/IMG]
I also replaced the shock, as the old one was the original hehe.
[/IMG]
Not perfect, but for under 5 bucks its a cheap lift :icon_thumby:
[/IMG]
Now you can see the height is a little higher, and the tires didn't rub at all after that
Hope this helps someone like me without alot of money, that has to make their own stuff to have fun with :icon_welder:
(By the way this mod throws the Camber Angle off a little bit)
i finnaly got the pics to show up in the post lol i didnt know how to post pics at first
Cool. Now you just gotta get an Alignment to fix your camber!
Don't ya think them hockey pucks might deterioate and evetually sag over time? I like the washer idea better. :icon_thumby:
Just keep an eye on them. l know in the Jeepin' world alot of guys use hockey pucks for body lifts. (Jeeps were my prior 4x4 life)
Over time, they will dry rot and start to fall apart...
That could be due to an issue with the quality of the hockey puck, l dont know. But there are lots of writeups and body tubs coming loose from pucks rotting away.
yea this was just my temporary setup, i took the hockey pucks out because of the camber. Now im running 235/75 R-15's an they're perfect for what i use my truck for (mudding,trailing):icon_thumby:
