8.8 carriers
Haleyes
10+ Year Member
28 spline and 31 spline
Do they have the same carrier? Obviously, the spiders are different but are the carriers different?
Hale
I would think the carrier would be the same.
The one thing I could see being differant would be the cross pin size. I know some are 3/4 and 7/8. My full size 31 spline 8.8 is 7/8's and I think all other 31 spline 8.8's are 7/8's. Mybe the 28 are the 3/4?
All 28s are 3/4" pin, yes. Most 31s are 7/8" pin (except some very early 31 spl 8.8s).
No, the carriers are NOT the same.
the only common part between the 28-spline and 31-spline 8.8" rears are the limited slip clutch discs (if so equipped)
The bore for the "pilot" on the back side of the axle pinions is larger because the side gear itself is larger (to maintain "wall" thickness with a larger diameter axle shaft hole.
However the gear (the teeth) is smaller, while the "spider" pinions are larger in actual diameter.
You can talk about the 3/4" cross-shaft "Low-Torque" 31-spline 8.8" axle but it's
unlikely you will ever see one, they were never terribly common
and all over 20 years old.
AllanD
