Go Back   The Ranger Station Forums > Styling & Electrical > Interior
Notices
Interior Seats, carpet, consoles and interior panels. Speaker/sub enclosures go in the Audio & Video forum. Forum sponsored by Aqua Graphix
Post New Thread Reply
Thread Tools Display Modes
Old 12-07-2008, 01:14 PM   #1
4x4TILL_I_DIE
4x4TILL_I_DIE's Avatar
Year: 1996
Make: ranger
Model: stx
Engine: 4.0
Class: 4x4
Used For: whatever
4x4TILL_I_DIE is on a distinguished road
Default Fitting a hurst T shifter
I want to put on a hurst T shifter on my 96 stx ranger but I don't know the size of the shifter threads, anyone know? heres the link to what it fits on.http://prostores3.carrierzone.com/se...Cpistol/Detail
__________________
96 4x4 stx, 5spd kenwood KDC-215S,reese class III, cooper wild spirt txr II, warn lockouts
soon to come, tinted taillight covers, new headlights
4x4TILL_I_DIE is offline   Reply With Quote
Old 12-08-2008, 04:17 PM   #2
4x4TILL_I_DIE
Year: 1996
Make: ranger
Model: stx
Engine: 4.0
Class: 4x4
Used For: whatever
Default
Is there any other way to get the shifter knob off other then a pair of vice grips and a really big hammer. If I ever did do it all I would be thinking would be man I wonder what this it doing to my shifter rod or my transmission.
__________________
Old 12-08-2008, 04:25 PM   #3
BDAB
BDAB's Avatar
Location: People's Republic of Michiganistan, United Socialist Republic of America
Year: 99, 96
Make: Lincoln, Ford
Model: Continental, F350 CC dually
Engine: 32v DOHC 4.6L V8, powerstroke
Class: fwd, 2wd
Used For: rice killer,Because I wanted it
BDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud of
Default
should just turn, you may need to work it a bit.
__________________
Quote:
Ain't it funny what power and money can do to the soul of a man.......
BDAB is offline   Reply With Quote
Old 12-08-2008, 04:54 PM   #4
cocoasranger
cocoasranger's Avatar
Year: 1989
Make: Ford
Model: Ranger
cocoasranger is on a distinguished road
Default
I don't know what's on one of them "newfangled" 96 Rangers, but on a 93 the shift knob is a force fit onto the shifter arm. The top of the arm has splines and the knob has a slightly undersized hole.The procedure for removing the knob is: first remove the shift emblem from the top by carefully prying off with a thin screw driver. Then heat the knob with a hair dryer of (preferably) a heat gun till it's too hot to grab tight. Then drive off the knob which should not take much force. This is because there is heat activated glue holding the knob as well as the press fit. Hope this helps.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel.
cocoasranger is offline   Reply With Quote
Old 12-09-2008, 08:46 AM   #5
4x4TILL_I_DIE
Year: 1996
Make: ranger
Model: stx
Engine: 4.0
Class: 4x4
Used For: whatever
Default
thanks I'll try that when I get the hurst if I can just find out if it will fit or not.
__________________
Old 12-20-2008, 12:03 PM   #6
gnardoom
Junior Member
Year: 1992
Model: ranger
Engine: 4L
gnardoom is on a distinguished road
Default
it wont fit because theres no threads, you have to weld a bolt to the end of your shifter, or if you dont have a welder you have to grind the shit out of your shifter until you can get a die on it and cut some threads. i put one of those t handles in my ranger when i was like 16 it was heavy and made the tranny whine because the weight of it makes your shifter fork rub harder then usual inside the trans. I think those are for automatics
gnardoom is offline   Reply With Quote
Old 12-20-2008, 12:25 PM   #7
The Jester Race
ΜΟΛΩΝ ΛΑΒΕ
The Jester Race's Avatar
Year: 1987, 2006
Make: Ford, BMW
Model: Bronco II, 325ci
Engine: 2.9, 2.5
Class: 4x4 Extreme, Racecar
The Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to beholdThe Jester Race is a splendid one to behold
Default
What you could do(what I did), drill out the threads on the shift knob so it just slips onto the shifter rod and drill a hole through the side and thread it, and use a set screw to hold it on. Ill post some pics later.
-Jester
__________________
Here we go...our step so silent
Here we go...our blooded trace
The Jester Race
In Flames
The Jester Race is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
