| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
i recently purchased a 89 ranger with a 2.9 for a 100 bucks. it started right up drove it 45 minutes home.. then the starter went out.. replaced that started up fine, but now it cranks over and over and wont start, ,i have shot starting fluid in it and still no start,, checked for spark,, its getting some spark but not sure if it is getting enough, i have no idea where to go from here on it. any suggestions?
Tweet
#2 | |
Year: 1988
Make: Ranger
Model: 4x4 2.9l 5speed
Engine: 2.9
Class: 4x4
Used For: getting stuck
Rep Power: 10 ![]() iTrader: (0)
gotta check the codes man. we have even less of an idea than you cause we are on the other side of the computer.
heres how http://www.therangerstation.com/tech_library/OBD_I.html
__________________
how to pull codes on the EEC-IV. http://www.therangerstation.com/tech_library/OBD_I.html do it! Quote:
Tweet
#3 |
Year: 84-90
Make: Ford
Model: Ranger,Taurus,kenmore
Engine: 2.9L
Class: 4X4
Used For: Anything i need
Rep Power: 0 ![]() iTrader: (0)
if you have no spark try the ignition moduale they usually go fast without warning, if you have some check the coil its at least a place to start
Tweet
#4 | |
Location: People's Republic of Michiganistan, United Socialist Republic of America
Year: 99, 96
Make: Lincoln, Ford
Model: Continental, F350 CC dually
Engine: 32v DOHC 4.6L V8, powerstroke
Class: fwd, 2wd
Used For: rice killer,Because I wanted it
Rep Power: 36 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
the 2.9 is a head ache but yeah check the codes.
__________________
Quote:
Tweet
#5 |
Junior Member
Year: 1988
1995
Make: Ford
Model: Bronco II
Explorer XLT
Engine: 2.9L 4.0L
Class: 4X4
Rep Power: 12 ![]() iTrader: (0)
you didn't mention if you're getting fuel. If you turn the key forward but not to engage the starter you should hear the fuel pump buzzing under the truck on driver side. if not check the fuel inertia relay. I had that prob and it drove me NUTZ for months.
Tweet
#6 |
i hear the fuel pump humming.. is there a way for me to check codes or do i need to get it to the shop to hook up on the computer? it just cranks and cranks but wont start.. i put a spark plug in the wire and it was firing but just looked weak, if thats possible.. if the ignition module was bad would it get spark at all? thanks for your input..
Tweet
#7 | |
Year: 99, 96
Make: Lincoln, Ford
Class: fwd, 2wd
look for an OBD1 scanner for a ford.
__________________
Quote:
Tweet
#8 | |
Year: 1988
Make: Ranger
Engine: 2.9
Class: 4x4
i posted a link that shows you how to get codes with just a piece of wire or a paperclip.
TFI has more to do with when to spark. the coil is what actually produces the spark.
__________________
Tweet
#10 |
had a buddy tell me to put a hair drying on the distributor for a while,, he said he had one and when it would rain he would have to use heat from a hair dryer for a while then it would start. has anyone ever heard of that? havent tried it yet but was just wondering before i do try it.
Tweet
#11 | |
Year: 99, 96
Make: Lincoln, Ford
Class: fwd, 2wd
just take the cap off and see if there is moisture inside the cap.
__________________
Quote:
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
